Maxarn58
Hello Bryn.
There are two possible locations for the tow-electrics.
Either under the floor in the boot, where the jack and
lugnut tool are, it should, if mounted correctly, be in the left
rear corner.
If not, then it is located behind the sidewall (left) in the luggage
compartment. (on my -06 RRS itīs there.)
The sidewall is mounted with clips, be careful when reattaching,
so You donīt damage them, they must be properly aligned when
pressing home.
Hope that this helps.
Best of luck
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Tue Jun 12 2012 1:40pm |
