![]() | Home > Maintenance & Modifications > RR Sport issues to fix - any advice? |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
Bonnet catch - Not a G4 thing, must be bent or something else
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Thanks MikeS, as ever!
Never bothered with my front sensors after the LR dealer tried to switch them on. They worked, but went mental so we switched them back off. If you really want to try it then drop Alan Edwards a message on the G4 forum, he works for JLR at Gaydon and was the one who told me how to get them all activated. I believe he managed it on the D3 he bought out of LR after the event.
Thanks Mike! So are you saying that the cruise control can be activated without the 'active' function? As that would do me fine!
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 ![]() ![]() ![]() |
Hi Mike
Err, not sure - you saying both temp controls have to be turned fully anti-clockwise for the aircon to work? If so, how do you set the temperature?! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE) - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
About the fuel flap.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
If you want maximum cold, then yes. I found this the other day too - selected full cold on my side but the air was cool rather than cold. Noticed the passenger side was set just above full cold. Set that side to full cold and the air temp dropped by several degrees almost immediately. The split zone feature can only handle a 4degC difference between zones (I think that's the figure) so it's not surprising that it can't do full cold on one side and warm on the other. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Yes on both counts. ![]() The temperature control of one zone can be compromised by the other zone being set to maximum heating or maximum cooling. True maximum heating or maximum cooling can only be obtained with both controls set to the same maximum state. The system will not achieve a temperature differential from left to right of more than 4°C (7°F). ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thanks guys, will try air con on full cold next time there's a warm day!!
