Home > Technical > Rear differential replacement
franciscolalas
Anyone with access to the LR labor times can tell me how much time is required to remove and replace the rear dif.
I was charged 8 hours for this, and they removed the wrong bolt on the hub carrier, so had to do a rear camber and toe alignment!!!!
Thanks in advance.
Post #343917 Thu May 17 2012 1:36am
