Home > Wheels & Tyres > Wheel weightings
Chauster
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Wheel weightings
Hi all I'm new to all this.
I am looking to buy a set 22's for my RRS.
. I have read on various posts that I should be looking for weight ratings of 1000kg per wheel. Since I'm looking for second hand wheels, is there any way of knowing what the rating is on a wheel, I.e stamp markings etc.?
Post #343616 Mon May 14 2012 11:18pm
Yes it will be stamped on the inside of the wheel, if it isn't, then don't buy them, RRS need to be 950kg minimum per wheel, overfinch and kahn are 1050kg per wheel i think, there are a lot of 22" wheels out there that are only 850kg per wheel which is dangerous on a RRS.
Don't believe a word of the top line of this post, i was fed some billybullshit and is incorrect Whistle The correct weight load for a RRS 20" wheel is 860kg Embarassed Thumbs Up
Post #343629 Tue May 15 2012 8:49am
seen genuine LR 20's rated as 925kgs..
but agree... 950 minimum for 22's if possible, any less and you risk failure RRS gone
Post #343633 Tue May 15 2012 9:13am
Supacat
Where did you get this from?
I believe mine are genuine wheels and stamped "only" 860kg each:
Post #343801 Wed May 16 2012 9:44am
Range rover sports must have got lighter since the launch of the facelift model Confused i was just going off information received. Obviously wrong Embarassed
Post #343803 Wed May 16 2012 9:51am
Still about 2,400 kgs Ady from what I can find on the web. Smile ON THE WAY: BMW F21 M140i
Post #343805 Wed May 16 2012 10:10am
I think up to 20" the weight rating is less critical due to the larger tyre wall cushion effect.
It's when you get to 22" you need more strength RRS gone
Post #343810 Wed May 16 2012 10:31am
Post #343815 Wed May 16 2012 10:45am
Supacat
I understand the point you are making but I don't think any of the wheel manufacturers quote dynamic loadings - it would have to be a different figure per tyre/wheel combination. I don't think there is a linear relationship either between static loading rates and dynamic loadings.
Ady - didn't want to contradict you just for the sake of it - just sharing info off my car...they well may be fakes Shocked
Post #343874 Wed May 16 2012 4:40pm
Hi Supacat
I had 850kg rated 22's on mine when I bought it..and distroyed 3 in as many months
The new ones are 950kg rated and so far so good.
Any kind of impact (pot hole, tarmac ridge) on a 22" alloy that is rated less than 900kg is just a matter of "when is it going to fail" not "is it going to fail" imho of course
The 20's offer more protection to point impact and maybe this is why yours are lower rated... or they may be very good fakes Laughing RRS gone
Post #343876 Wed May 16 2012 4:48pm
Supacat, you are quite correct, and i'm guessing yours are genuine if this previous post is anything to go by, http://www.rrsport.co.uk/forum/topic22636.html
My apologies if ive misled anyone, but it just goes to show, don't believe everything you hear Laughing Thumbs Up
Post #343900 Wed May 16 2012 9:16pm
