Home > Wheels & Tyres > Wheel weightings |
Yes it will be stamped on the inside of the wheel, if it isn't, then don't buy them, RRS need to be 950kg minimum per wheel, overfinch and kahn are 1050kg per wheel i think, there are a lot of 22" wheels out there that are only 850kg per wheel which is dangerous on a RRS.
Tue May 15 2012 7:49am |
seen genuine LR 20's rated as 925kgs..
Tue May 15 2012 8:13am |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
Where did you get this from? I believe mine are genuine wheels and stamped "only" 860kg each:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Wed May 16 2012 8:44am |
Range rover sports must have got lighter since the launch of the facelift model i was just going off information received. Obviously wrong |
Wed May 16 2012 8:51am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Still about 2,400 kgs Ady from what I can find on the web. ON THE WAY: BMW F21 M140i
Wed May 16 2012 9:10am |
I think up to 20" the weight rating is less critical due to the larger tyre wall cushion effect.
Wed May 16 2012 9:31am |
Wed May 16 2012 9:45am |
I understand the point you are making but I don't think any of the wheel manufacturers quote dynamic loadings - it would have to be a different figure per tyre/wheel combination. I don't think there is a linear relationship either between static loading rates and dynamic loadings. Ady - didn't want to contradict you just for the sake of it - just sharing info off my car...they well may be fakes |
Wed May 16 2012 3:40pm |
Hi Supacat
Wed May 16 2012 3:48pm |
Supacat, you are quite correct, and i'm guessing yours are genuine if this previous post is anything to go by, http://www.rrsport.co.uk/forum/topic22636.html
Wed May 16 2012 8:16pm |
