![]() | Home > General > performance upgrade |
The pre-2010 cars can have the ecu re-flashed by tuners yes. |
A 3" exhaust, how old are you 17 |
nomnrz Member Since: 01 May 2012 Location: victoria Posts: 6 ![]() ![]() |
will the remap wake it up its so slow off the mark Nomnrz |
No imnot 17 im going off what ive been told ive never owned v6 car before always v8's Nomnrz |
Remap will definitly wake the car up |
The re-map will not totally get rid of the "pause" on the pickup from standstill... but it goes a long way towards it.
So should i be looking at boosting the turbo?
all done via the ecu re-map |
Thank you very much for your help |
Slow of the mark, try using 1st gear |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
that's where I'd go 1st...cheaper as well. |
J17YSP Member Since: 12 Apr 2012 Location: london Posts: 16 ![]() ![]() ![]() |
i want to get rid of the delay at the pick up on tdv6 heLLp see how its hell for me lol RRS HST J17YSP |
As said above, use 1st gear by knocking it into command shift on approach to the junction or roundabout then select 1st gear |
