Home > Technical > Air Compressor
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
Air Compressor
lo all,
After starting my RRS, I can hear my compressor whirring away and working.
However after 3-4 mins the compressor cuts out and I get the amber warning light on the dash stating access height only. If I turn the engine off and on again it clears the fault and the compressor works for 3-4 mins again and then I get the warning light again.
Could this be the fuse or relay or does it mean the compressor is knackered?
James
Post #339159 Sun Apr 08 2012 10:52am
timcom0
Re: Air Compressor
Had similar problem lately, lift the bonnet remove battery cover the fuse
box lid that is there in front of battery and therei is a yellow fuse 60, check it
that was the same fault and problem on mine, £2.50 from ebay delivered
hope it's the same for you matey
Post #339165 Sun Apr 08 2012 12:45pm
chapman_i.t
Can you be a little more specific which fuse this is?
Can I tell by looking at it if it is blown?
Thanks
James
Post #339179 Sun Apr 08 2012 4:05pm
timcom0
hi, yes you can tell if it is blown, yes yellow and look on lid and highlights
air suspension, specific enough Laughing
Post #339181 Sun Apr 08 2012 5:20pm
chapman_i.t
Sorry to sound dim.
How can I tell if it is blown?
Would it be worth just buying a new one anyway for £2.50?
James
Post #339187 Sun Apr 08 2012 5:48pm
timcom0
Hi, it looks like a small yellow relay with a clear top/lid that can be removed,
if it has blown it will be quite apparant and then to test push the two parts
together and should cure problem then just order a new one as I did.
Was over the moon when realised for once with this motor something actually a cheap fix.
Post #339189 Sun Apr 08 2012 5:56pm
chapman_i.t
Ok,
I have just been out to check that fuse and it all looks OK from what I can see. It isnt discoloured and I cant seem to find any breaks in the fuse. However I have ordered a new fuse just to rule that out.
If this doesnt cure the fault, do you have any other ideas what the fault might be?
Post #339191 Sun Apr 08 2012 6:11pm
timcom0
Would suggest make a friend of a local garage that carries snap on or other
software to interogate the computer of the RRS, because sometimes cheaper
them telling you what's not gone opposed to what has.
That's why when mine acted up took it local garage who told me that it wasn't the compressor
so I started to look at why and when it went, turned out when I ran the battery down then jump started
again that's what blew the fuse/relay, hope this helps, cheers
Tim
Post #339193 Sun Apr 08 2012 6:21pm
chapman_i.t
OK thanks Tim.
I will look into this then at at a local garage.
I have recently had a new battery put on my RRS.
Its just strange as when I start the engine I can hear the compressor working, then at any random time usually quite quickly now the amber light comes on and I cannot hear the compressor whirring. Until I turn the engine off and back on again.
Post #339194 Sun Apr 08 2012 6:24pm
timcom0
That's what made me think it was the little relay cause mine
was the same like that's how long it took the relay to heat and trip out.
When I looked at mine first it wasn't obviious only that i tought i would
try and push them together just to see, look at the yellow relay along side the others and
then if in doubt put a wire betwenn them once it trips out, you know what i mean
Post #339197 Sun Apr 08 2012 6:36pm
chapman_i.t
Ok thanks Tim.
I will try that, I have a new one on its way anyway so fingers crossed!
Post #339200 Sun Apr 08 2012 6:41pm
chapman_i.t
One more thing...
How do you remove the relay?
Do you need a special tool?
Post #339203 Sun Apr 08 2012 6:44pm
timcom0
just pulled it out with fingers, a little tight but no probs
Post #339218 Sun Apr 08 2012 8:28pm
shepp
Hello Chapman
your issue may be an internal leak on your compressor, caused by a weak exhaust valve. My rrs started by intermittantly flashing up amber, then eventually happened as yours is, every time. also it would be worth drying out the air dryer at the same time. The TSB below explains how to upgrade the compressor.
http://www.rrsport.co.uk/gallery/albums/us...rogram.pdf
Post #339233 Mon Apr 09 2012 8:08am
chapman_i.t
OK,
How do I go about doing this?
Is it a big job, is there a breakdown DIY knocking about anywhere?
Post #339235 Mon Apr 09 2012 8:15am
