![]() | Home > Technical > Air Compressor |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
Had similar problem lately, lift the bonnet remove battery cover the fuse
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
Can you be a little more specific which fuse this is?
hi, yes you can tell if it is blown, yes yellow and look on lid and highlights
Sorry to sound dim.
Hi, it looks like a small yellow relay with a clear top/lid that can be removed,
Ok,
Would suggest make a friend of a local garage that carries snap on or other
OK thanks Tim.
That's what made me think it was the little relay cause mine
Ok thanks Tim.
One more thing...
just pulled it out with fingers, a little tight but no probs |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello Chapman
OK,
