Home > General > Tapping my brake pedal at low speeds = clunk
Mixy
Hi,
My 55 2.7 HSE has a clunk from what feels like the OSF side when i hit the brakes hard, it does not happen when i brake slightly. The last MOT noted play in the OSF wheel bearing, could this be it? Has anyone else experienced this? It sounds like a anti roll bar bush or similar?
Thanks
Post #335835 Thu Mar 08 2012 10:42pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Could be a sticky brake calliper / pot.......... Question Question It could also be the dreaded "knockety-knock" from the suspension bushes or as the MoT has picked up - a bearing. Whizz it into a specialist and get the SP - as with all knocks and noises, far too many "if's" Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #335843 Thu Mar 08 2012 11:28pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
check for dreaded knock knock by steering left to right quite rapidly at about 25mph
Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #335847 Thu Mar 08 2012 11:56pm
I think this is a different problem to the ubiquitous "knock" that we all know and love.
I'd say bearing first. One further way of analysing wheel bearings is to listen for noise changes as lateral load is applied. Usually a worn front wheel bearing would make a noise when it is loaded on the outside of a turn. You might be able to test in a safe place (empty car park for example) by braking hard whilst carrying out a right turn. This will load the OSF wheel bearing. DOes it still knock? Is it worse or lessened?
Obviously, care is required when turning and braking!
Might also be a top mount? Not sure if air suspension would suffer this like normal struts can? 2012 SDV6 - it's missing a couple of cylinders
Post #335850 Fri Mar 09 2012 12:11am
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Are you sure it's not the solenoid for the auto selection stick? Mine makes a clonk when you touch the brake.
Post #335854 Fri Mar 09 2012 6:25am
MAW
+1 - my thoughts. Tap pedal whilst at rest to experience noise then see if that is it....
Post #335855 Fri Mar 09 2012 6:46am
Mixy
Thanks guys,
I am going to replace the front discs and pads and at the same time do the Osf wheel bearing. Some of these comments give me some confidence that we may resolve it doing the above. Also, I notice a very very slight 'rumble' or vibration on the steering wheel whilst turning sometimes, I hope this is the bearing......
I will revert my findings here very soon...
Post #335857 Fri Mar 09 2012 7:07am
That sound has all the hallmarks of a wheel bearing mixy, but just check that your wheel bolts are tight on your front wheel first. Thumbs Up
Post #335859 Fri Mar 09 2012 7:42am
Mixy
I had two new tyres fitted last week and the wheel bolts were air gunned on. My guy checked all bushes/mounts etc and the only play he found was the bearing. This was also an advisory on the mot from feb12. Reckon that a new bearing will Cyrene both. Seen them on eBay for circa £70, does any know better LR parts supplier?
Post #335861 Fri Mar 09 2012 7:53am
That doesn't necessarily mean that they are still tight
Post #335868 Fri Mar 09 2012 8:34am
Wheel bolts were airgunned on? Did they use a torque wrench to finish the tightening having had the guns set to minimum or were the guns just set to maximum?
Wheel bolts should not be fitted with airguns. Great way to end up with bolts that are impossible to undo or are damaged.
Rumble on turning does sound like a wheel bearing. 2012 SDV6 - it's missing a couple of cylinders
Post #335869 Fri Mar 09 2012 8:35am
Aitchy
"they all do that sir" (honestly) My 2010MY RRS 3.0 TDV6SE is Nara Bronze with Almond leather, straight grain walnut trim, 20" 15 spoke alloy's, mood lighting and power fold mirrors Gone
Post #335971 Fri Mar 09 2012 8:01pm
Mixy
Okay..... i need some more help here....
I have just replaced the faulty wheel bearing, the two rods that connect the track rod ends to the steering rack and all the disk/pads. The clunk is still here. This is the scenario;
I drive the car and jab the brakes and it clunks for the lower suspension area.
I drive the car and slowly press the brake and nothing, no clunk.
I drive the car in reverse and jab the brakes, nothing, no clunks.... mmmmm this could be a clue!
I drive over a speed bump at low speed, no clunk.
I drive over a large pot hole and the quick jolt to the suspension makes the clunk.
I have no play in the steering.
The clunk sounds like it is coming from a bush or wishbone mount, the clunk also has a kind of 'dry' squeak with it suggesting that it is also rubber.
Any thoughts, any one had this problem before?
Big Cry Shocked
Cheers guys.
Post #337782 Sun Mar 25 2012 7:08pm
rrsboy
ARB
slowly = ARB won't be obvious
slowly? ARB wouldn't be obvious
slowly = ARB wouldn't be obvious
ARB
ARB
ARB
my guess = it's the ARB. Try the reverse test at speed of 30mph+ (!!!) to confirm this
Post #337806 Sun Mar 25 2012 9:12pm
Mixy
Thanks RRSboy,
Problem solved..... or will be when the work is done on the 4th April.
I took my car down to www.landranger.co.uk in Stockport, they test drove the car then used a few 'levers' to diagnose the problem. It is my NSF lower wishbone rear bush that has gone. The part is circa £170 for a genuine item and fitting is £35 per hour, appx 4 hours work, whilst they are at it they will replace the ARB bushes as well.
Hopefully this will solve the problem.
If anyone is in the Stockport/South Manchester area, these guys are worth a call, great value and excellent knowledge about LR product.
I will update this thread post work...... fingers crossed.
Post #337916 Mon Mar 26 2012 8:04pm
