Home > General > Tapping my brake pedal at low speeds = clunk |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Could be a sticky brake calliper / pot.......... It could also be the dreaded "knockety-knock" from the suspension bushes or as the MoT has picked up - a bearing. Whizz it into a specialist and get the SP - as with all knocks and noises, far too many "if's" L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Thu Mar 08 2012 11:28pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
check for dreaded knock knock by steering left to right quite rapidly at about 25mph
Thu Mar 08 2012 11:56pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8991 |
I think this is a different problem to the ubiquitous "knock" that we all know and love.
Fri Mar 09 2012 12:11am |
Jmac Member Since: 17 Feb 2011 Location: South Posts: 125 |
Are you sure it's not the solenoid for the auto selection stick? Mine makes a clonk when you touch the brake. |
Fri Mar 09 2012 6:25am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
+1 - my thoughts. Tap pedal whilst at rest to experience noise then see if that is it.... |
Fri Mar 09 2012 6:46am |
Mixy Member Since: 20 Feb 2012 Location: Cheadle Posts: 39 |
Thanks guys,
Fri Mar 09 2012 7:07am |
That sound has all the hallmarks of a wheel bearing mixy, but just check that your wheel bolts are tight on your front wheel first. |
Fri Mar 09 2012 7:42am |
I had two new tyres fitted last week and the wheel bolts were air gunned on. My guy checked all bushes/mounts etc and the only play he found was the bearing. This was also an advisory on the mot from feb12. Reckon that a new bearing will Cyrene both. Seen them on eBay for circa £70, does any know better LR parts supplier? |
Fri Mar 09 2012 7:53am |
That doesn't necessarily mean that they are still tight |
Fri Mar 09 2012 8:34am |
Wheel bolts were airgunned on? Did they use a torque wrench to finish the tightening having had the guns set to minimum or were the guns just set to maximum?
Fri Mar 09 2012 8:35am |
Aitchy Member Since: 19 Nov 2009 Location: Peterborough Posts: 45 |
"they all do that sir" (honestly) My 2010MY RRS 3.0 TDV6SE is Nara Bronze with Almond leather, straight grain walnut trim, 20" 15 spoke alloy's, mood lighting and power fold mirrors Gone |
Fri Mar 09 2012 8:01pm |
Okay..... i need some more help here....
Sun Mar 25 2012 7:08pm |
ARB
slowly = ARB won't be obvious
slowly? ARB wouldn't be obvious
slowly = ARB wouldn't be obvious
ARB
ARB
ARB my guess = it's the ARB. Try the reverse test at speed of 30mph+ (!!!) to confirm this ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Sun Mar 25 2012 9:12pm |
Thanks RRSboy,
Mon Mar 26 2012 8:04pm |
