Home > Maintenance & Modifications > Squealing wheel/brakes |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 |
It more than likely a glazed pad. It's when one of the pads gets hot and it.....well burns it and puts a hard film on it if you like, hence making it squeal. |
Sun Jan 29 2012 7:37pm |
norlan Member Since: 21 Jun 2011 Location: Moray Firth Posts: 45 |
Just had exactly the same problem (08 HST 35k miles), mine was back left. Turned out to be the pads, ended up having all 8 changed. Not only has the noise gone away but I had forgotten just how good it feels to be able to stop quickly !!! |
Sun Jan 29 2012 10:37pm |
pintof80 Member Since: 23 Oct 2011 Location: Edinburgh Posts: 13 |
Sounds like I need to start saving up for a new set of pads then. 2012 RRS SDV6 HSE
Sun Jan 29 2012 11:23pm |
Jmac Member Since: 17 Feb 2011 Location: South Posts: 125 |
See if you can see the thickness of the pad by looking through the wheel spokes. There should be more than 5mm between the pad carrier and the disc.. Beware that the inner pads normally wear quicker as they get hotter. If there is quite a bit of meat left on the pad, try giving the brakes a bit of stick.. My race car's brakes squeal like a pig when it's been driven slowly for a while but go nice and quiet when they are hot. I think it's unlikely to be pad transfer on old discs and pads - unless you have given it some stick recently. J |
Mon Jan 30 2012 7:07am |
OK, I'll try to get a good look at the pads at the weekend. 2012 RRS SDV6 HSE
Tue Jan 31 2012 11:16pm |
