Home > Technical > oil leak from suspension and new brake pipes required at rea
Adam270
hi my 06 range rover sport failed its mot today Big Cry on corroded brake pipes at the rear and i just wanted to know what sort of price i would be looking at to have them replaced . it also got an advisorey for a oil leak coming from the suspension at the rear does any one know what this could be thanks Big Cry Range Rover Sport 2.7HSE
22" overfich Wheels in Black
s/c Front and side Grills
Rear Screens
HST Rear Spoiler
Quad Exhaust
De Badged Front and Rear
Side Steps
Post #328514 Tue Jan 17 2012 10:38pm
Bodsy
Site Sponsor
brake pipes (to do them with LR Pipes) is a body off job......
oil leak coming from suspension can only really be a leaking shock absorber as the rest is air. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #328779 Thu Jan 19 2012 4:57pm
mark hamster
does body off mean what it says..? does it just lift off or somthing Question
Post #328918 Fri Jan 20 2012 1:37pm
Bodsy
Site Sponsor
two post lift, 8 bolts and about 5 connectors & the fuel pipe . Mind you, some of the conectors need more bits off to get to them.
Body then lifts away from the Chassis.
There are other ways to do thepipework, but not LR approved. but your local Indi may well have a way to do them. Bodsys Brake Bible
See it HERE
Post #328923 Fri Jan 20 2012 2:54pm
Bob.
If it's not a damper leaking and your car is fitted with the dynamic response system (look for a second hydraulic fluid reservoir under the bonnet on the opposite side of the radiator to the coolant and power steering reservoirs), it could be the rear anti roll bar actuator leaking - not that uncommon I gather.
Post #328968 Fri Jan 20 2012 9:54pm
Baron
Just had 5th year service with only 43k on the clock. Rear ark arm of anti roll bar leaking!!!!
Quote is best part of TWO THOUSAND QUID Big Cry
Service was bad enough @ £663.85 Thud
Talking to the bloke that brought the car back it sounds a common problem!!!!
Hoping LR might give a discount seeing as the car has so few miles (Holding my breath at the moment).  SDV8 vogue SE.
Corris grey and ivory leather + most of the toys.
Limited edition RRS model number 0001 Smile
Gone TDV8 RR Sport. Never to be forgotten.
Wife has an i8 BMW
Post #329241 Mon Jan 23 2012 6:21pm
Bob.
The ARB is about £860 and the LR quoted time to change is under 3 hours so £2k sounds well over the top.
Post #329244 Mon Jan 23 2012 7:38pm
Baron
Bob.
Yes Embarassed To include front brake disks. Still a Shocked  SDV8 vogue SE.
Wife has an i8 BMW
Post #329267 Tue Jan 24 2012 12:19am
