Home > Maintenance & Modifications > Front rotors warped |
I dont know what mine had - but there was a modified part fitted to my 2011 sport to stop the breaking wobble from 70-50 Mike
Wed Dec 14 2011 9:58pm |
Bob Member Since: 19 Aug 2006 Location: Pump No. 3 Usually! Posts: 49 |
I had this a couple of years ago. I changed the rotors and pads for the MOT (I used non-standard rotors and pads), and 1500 miles later, I got vibration through the steering wheel when braking. I changed the rotors again, and 1500 miles later the braking vibration came back. As a last resort, I swapped the pads to original Brembo pads, and from then on, the vibration started too reduce. 2,000 miles later, the braking is as smooth as when it was new. So, as unlikely as it sounds, it was actually the cheap pads that was causing mine. Hope this helps. Bob. |
Fri Dec 16 2011 6:36pm |
