Home > General > Range, how low have you dared to go?
Sabre1966
United Kingdom 2008 Range Rover Sport TDV6 HSE Santorini Black
Found myself really low on fuel and eventually pulled into a station and the range remaining was 2 miles, how much lower I wonder would it go before it ran out?
Post #324162 Tue Dec 06 2011 7:27pm
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Re: Range, how low have you dared to go?
Have managed 15 very scary miles with 0 range left. Not something I want to repeat!
Post #324167 Tue Dec 06 2011 8:31pm
edvarski
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I've not run much lower than 25 in the RRS, but when we had a petrol Freelander I've run it so low that the needle had passed the empty marker on the fuel guage with clear air between them Smile
It was her company car at the time and she got free fuel, so I wasn't going to pay for fuel until I picked her up at M'cr airport. I figured it was downhill on the M62 from snake pass Whistle
The fuel guages are reasonably inaccurate, but is more of an issue if you run out in a diesel compared to a petrol.
Post #324171 Tue Dec 06 2011 8:57pm
MJF
England 2008 Range Rover Sport TDV8 HSE Java Black
I have a TDV8 and i went 8 miles after Zero on the fuel guage... Thankfully found an open garage
Post #324212 Tue Dec 06 2011 11:06pm
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
Hang on, i'll ask the Wife. She makes a habbit of bringing ours home with zero milage left on the computer. Its normaly on a fri when she knows i ditch my van and will use the rrs, and i would say its around 15 miles to the nearest station, the one that swmbo drove right past on the way home oblivious to that little light flashing away on the dash.
Post #324227 Wed Dec 07 2011 8:46am
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
I once drove for about 1-2 miles.
However!!! An interesting fact: I went to FastLane today and we actually talked about the range you can cover once you hit 0 miles.
What they told me at the garage, was that apparently, your RRS leaves 1 gallon in reserve. So even if you hit 0, you still have 1 gallon left.
On the other hand, 0 does not mean 0. It is an average estimate of how many miles you can still cover. All depends on how aggressively you drive.
What is important to consider, is to never leave a small volume of petrol, otherwise all the rubbish-like bits accumulate over time and stay on the surface. Once the petrol is about to run out all the dusty particles etc go straight into pipeline and may reach engine and that is not recommended. I am not saying your engine will explode, it is simply not recommended. Vadim A.
Post #324351 Thu Dec 08 2011 3:56am
Agree with Vadim, I've heard that you end up drawing the s Censored t into the engine.
Not that that stops Mrs Bean from returning the car once in a while running on fumes. Fortunatly I've not had the issue in the RRS, but in previous cars, I've had to drive 10 mils on 'zero' in order to fill up Rolling Eyes ON THE WAY: BMW F21 M140i
Post #324400 Thu Dec 08 2011 1:18pm
