![]() | Home > In Car Electronics > iPhone integration RRSMY12 |
V8V Man Member Since: 12 Jan 2011 Location: Reading Posts: 65 ![]() ![]() ![]() |
Hi
Josh Bear Member Since: 19 Oct 2011 Location: UK Posts: 60 ![]() |
Hi
Voiceman1uk Member Since: 25 Nov 2011 Location: Bedfordshire Posts: 7 ![]() ![]() |
Thanks both for your reply,my issue is when connected via cable I hear no music, works fine via bluetooth but of course using that you loose the ability to search for music on the iPhone..... Dealer has been very supportive but LR technical support are trying to fob me of with "its an apple issue", could well be but given its brand new to my mind they need to sort it rater than passing the problem back to me.. |
Hi
Thanks Josh...I have tried a iPhone 4 and 4s with IOS5 on dealer tried 3gs IOS 4 all same problem if you unplug the cable and plug it back it you get about 2 mins of music then it stops again. Make sure when you test that you have the cable selected you will know because you will able to browse through your music collection
Hi
Hi Josh
Thanks. Appreciate that.
gavinj Member Since: 28 Nov 2011 Location: Devon Posts: 1 ![]() ![]() ![]() |
Guys
Naz Member Since: 10 Mar 2010 Location: Birmingham Posts: 29 ![]() ![]() ![]() |
Having the same problem with MY 12 and 4S. It keeps wanting to stream over Bluetooth rather than continue to send music via cable. Only solution is to let it do it once and go into Bluetooth menu and select change device and deselect it, doesn't do it again for rest of the journey.
U may wana check out A2DPblocker app havn't tried it yet but it goes to prove its a recognised problem Current: MY 12 HSE Autobiography Kit
Thanks all for the feedback looks like LR have issues in both MY11 & 12, still waiting on a response LR but to be honest what's annoying me most is the immediate response "it's an apple issue and all I had to do was disconnect and reconnect the cable"..which by the way does not work either, well least for any more that 3 mins And then trying to close the case and asking if I could speak to an independent specialist to see what they thought |
After lots of discussion with both my dealer and LR customer services we have come from its and Apple issue and their is nothing they can do to its now under investigation by LR, seems the issue is across the Disco, Sport and Evoque Range...where this will end is anyone's guess!!!! |
hsleiman Member Since: 26 Aug 2010 Location: West Virginia Posts: 1 ![]() ![]() |
Hey everyone, just wanted to chime in and say this is definitely an Apple issue. People are having trouble with it in all sorts of cars. There is a lengthy thread on the Apple support forums where Volvo owners are complaining of the same issue.
