Home > In Car Electronics > Radio Interference! |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
Just a thought, but the mornings when you have had the interference haven't coincided with using either the front screen demist program (blows hot air to screen and activates heated front and rear screens) or with using the heated rear screen? The ariel is part of the rear screen and if you have a bad earth there it will cause the interference you describe which will only be there when the heated rear screen is energised. |
Sat Nov 19 2011 8:32pm |
Tonyrec Member Since: 15 Mar 2009 Location: Cumbria Posts: 306 |
Hi,
Sat Nov 19 2011 9:27pm |
bootz Member Since: 14 Oct 2011 Location: England Posts: 86 |
This happened to me on a previous TDV8 for no apparent reason.
Sun Nov 20 2011 3:38pm |
Apparently there is a TSB for this so it's booked in for Tuesday. We will see what happens. |
Fri Nov 25 2011 10:19pm |
This is my experience with this fault so far.
Sun Dec 04 2011 5:03pm |
bellcrank Member Since: 19 Jan 2015 Location: Kent Posts: 11 |
I have the very same intermittent symptom in my 2011 HSE, which has occurs approximately once a month, the latest time yesterday. The crackling white noise cannot be cleared except by turning off the ignition and waiting maybe 15 minutes minimum. So, if it happens on a long trip, I'm stuck with it,. Did anyone here get it fixed,and if so how? |
Thu May 28 2015 8:57am |
hill1996 Member Since: 30 May 2018 Location: west sussex Posts: 1 |
My RRS 2005 keeps randomly popping out of speakers almost like a static shock does its every 20 (ish) seconds
Fri Jun 01 2018 5:55pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
I've had this also,, doesn't happen very often but only ever at startup. Didn't know there was a TSB for it, might look into it if it happens again. 2010 RRS, TDV8
Fri Jun 01 2018 7:30pm |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
anyone had a fix for this? I seem to get this if i unlock my car and dont start the car within about 5 minutes all speakers make static noises RRS TDV6 2010 |
Mon Dec 03 2018 1:25pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1841 |
Have you checked if the TSB has been applied to your car? 2023 P440e SE Dynamic on order -cancelled
Mon Dec 03 2018 1:38pm |
how do i do that lol RRS TDV6 2010 |
Tue Dec 04 2018 7:28am |
Dealer? 2023 P440e SE Dynamic on order -cancelled
Tue Dec 04 2018 8:41am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
If this sorts it out, perhaps you could be kind enough to obtain the TSB number from your garage and post it here for the information of our members. |
Tue Dec 04 2018 11:13am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Could try this one issued 09/2010 LTB00299 but may not be the one as relates to Infotainment System Inop/Locking Up.
Tue Dec 04 2018 11:15pm |
