Home > In Car Electronics > Radio Interference!
Tonyrec
Radio Interference!
We have had our car now for nearly 8 weeks, however, there is an intermitant seriously annoying problem.
Twice now (including this morning) i have started the car and driven off but when I turn on the radio all i get is a very loud morse code/aerial interference sound coming out of all the speakers (crackling). It does not go away either by turning the radio off and back on again or by pulling over and restarting the car.
It sounds as if the aerial lead has become disconnected.
The journey this morning was only 5 minutes long but my passengers had to put their fingers in their ears for the whole journey.
When I returned to the car later, all is fine and dandy once again.
This is a serious problem as if we are on a longer journey it would render the car undriveable.
I am seriously concerned because of the very nature of the fault, when it goes into a dealer to get this fixed, it will probably not happen and will therefore not be cured. Big Cry
Has anyone else heard of this fault before can give me some advice please?
Post #321770 Sat Nov 19 2011 12:13pm
simon1233
Just a thought, but the mornings when you have had the interference haven't coincided with using either the front screen demist program (blows hot air to screen and activates heated front and rear screens) or with using the heated rear screen? The ariel is part of the rear screen and if you have a bad earth there it will cause the interference you describe which will only be there when the heated rear screen is energised.
Post #321804 Sat Nov 19 2011 8:32pm
Tonyrec
No, nothing else is turned on. Odd thing is that it stays on even when the radio is off so it's always there until you stop and turn the engine off!
Post #321813 Sat Nov 19 2011 9:27pm
bootz
This happened to me on a previous TDV8 for no apparent reason.
I started the engine and got what sounded like a pirate radio station with very bad reception coming through the speakers. The noise continued even when the radio was switched off as well. Shocked
I drove the car for about ten minutes then stopped and switched the engine off for about 10 minutes and the sound had gone - and never returned Confused
The other strange thing when i switched off there was a definate high pitched single tone coming from somewhere in the car that i could hear from outside - go figure! When I returned the noise had stopped and the CD and radio worked as normal....
This only happened once so i never had to try to get it fixed. Confused
Post #321864 Sun Nov 20 2011 3:38pm
Tonyrec
Apparently there is a TSB for this so it's booked in for Tuesday. We will see what happens.
Post #322656 Fri Nov 25 2011 10:19pm
Tonyrec
This is my experience with this fault so far.
Bearing in mind that it is a very intermittant fault.....serious fault if it was to come on again whilst driving. Phoned the first dealer, booked the car in explaining the fault and was told that if it didn't occur when they had the car then it would be returned to me in the same condition. Once I explained that it has only happened 4 times in 8 weeks, i was told that they could arrange to keep it 'long term' in the hope of the fault appearing.
Wasn't too happy about this for obvious reasons.......
Telephoned the second dealer and was told that they had not heard of this before but would contact a technician.
Received a phone call a few hours later saying that there was in fact a TSB for this and to book it in to get it sorted.
i did this and fingers crossed after a download and re boot etc the fault was to do with the amplifier receiving some sort of charge from startup.
I was pleased and it just goes to show that not all dealers are the same!!!!!
Post #323903 Sun Dec 04 2011 5:03pm
bellcrank
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
I have the very same intermittent symptom in my 2011 HSE, which has occurs approximately once a month, the latest time yesterday. The crackling white noise cannot be cleared except by turning off the ignition and waiting maybe 15 minutes minimum. So, if it happens on a long trip, I'm stuck with it,. Did anyone here get it fixed,and if so how?
Post #463085 Thu May 28 2015 8:57am
hill1996
England 2005 Range Rover Sport TDV6 HSE Java Black
My RRS 2005 keeps randomly popping out of speakers almost like a static shock does its every 20 (ish) seconds
Very annoying has anyone else experience this and know what the problem is ?
Post #557933 Fri Jun 01 2018 5:55pm
gogsy1956
I've had this also,, doesn't happen very often but only ever at startup. Didn't know there was a TSB for it, might look into it if it happens again. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #557945 Fri Jun 01 2018 7:30pm
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
anyone had a fix for this? I seem to get this if i unlock my car and dont start the car within about 5 minutes all speakers make static noises Censored Censored Censored Censored RRS TDV6 2010 Smile
Post #570348 Mon Dec 03 2018 1:25pm
jimbg
Have you checked if the TSB has been applied to your car? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #570350 Mon Dec 03 2018 1:38pm
Sham91
how do i do that lol RRS TDV6 2010 Smile
Post #570404 Tue Dec 04 2018 7:28am
jimbg
Dealer? Whistle Laughing 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #570407 Tue Dec 04 2018 8:41am
Oldandconfused
If this sorts it out, perhaps you could be kind enough to obtain the TSB number from your garage and post it here for the information of our members. Thumbs Up
Post #570412 Tue Dec 04 2018 11:13am
Could try this one issued 09/2010 LTB00299 but may not be the one as relates to Infotainment System Inop/Locking Up.
Post #570467 Tue Dec 04 2018 11:15pm
