![]() | Home > General > Fuel Burning Heater |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
I have heard that the FBH is only there to assist the warm up of the engine. It operates when the engine is started, and warms the water so as to get engine temperature up quicker. The smoke at the front of the car is the exhaust of the heater,comes out front n/s wing. I have also heard that it can be converted to remote operation before engine start up. At about £200 Look at Webasto web site. Says it can be activated on a timer or from 1000 mtrs itisme |
You can get a few 3rd party systems that will get the FBH started without starting the engine. I had one fitted that started the FBH using a phone number - fantastic as I phoned the car up 20 minutes before I was due to go out on a cold morning and the car was nice and warm with all iced up windows cleared. Well worth the investment IMO. 2005 Zambezi TDV6 - Gone but not forgotten
Hi,Very Annoyed, Have you got a contact number for the fitters that did this for you? I have tried to contact the engineers on the Webasto Site but none of them reply. Also as i bought my RRS used i dont know if it had a remote, and was kept by previous owner or lost.It must have a reciever to use a remote. itisme |
99% sure you will not have a remote as very few people fit these kits. Mine was a unit we bought as a group buy on this site but pretty sure site sponsors bellautos do something similar. 2005 Zambezi TDV6 - Gone but not forgotten
Tonyrec Member Since: 15 Mar 2009 Location: Cumbria Posts: 306 ![]() ![]() ![]() |
Thanks chaps for sorting this confusion |
Yes and no The Park heater is a software option to enable the option on the central screen and extra hardware for the remote Uses the same hardware to generate the heat Which works as the car decides to speed up heating if you dont have the enable park heat...which can be enabled Mike 2014 Facelift Discovery |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
Fuel Burning Heater (FBH) - Fitted to all Diesels to speed engine heat-up.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
on my 10 plate MY10 the RPH is insane! the range of the remote is amazing |
As mentioned - timed climate is software, remote is addition of hardware for the remote only and software and all use the base kit (hardware) for the FBH ![]() 2014 Facelift Discovery |
Krx84 Member Since: 05 Oct 2011 Location: Clayton le Moors Posts: 19 ![]() ![]() |
Any body have the part numbers for the remote hardware? Install guide if possible? RRSport - 2010 |
JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89 ![]() ![]() |
You will ned to have the timed climate activated in order to use the remote (i think !!)
What about the key fob cost? Any chance for part numbers?? Help appreciated...my mate is an auto technic so im confident he must have the autologic...did you fit the remote aswell? RRSport - 2010 |
Just going to order it from land rover tomorrow will get a remote from them as well
Yes had a look, but i thought the parts would be diifeent in a disco...i hope i can find someone to activate the option soon...im from lancashire or else id be coming to you first thing in morning!! RRSport - 2010 |
