![]() | Home > Maintenance & Modifications > remaps ?? |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
The only downside I have found so far is wanting to hear that glorious sound as I push the loud pedal. It's addictive!
There are a number of reasons why land rover dont send them out mapped:
steveee Member Since: 03 May 2011 Location: orpington Posts: 34 ![]() ![]() ![]() |
ok thanks you two. does this mean if they are remapped here they do not pass our emissions test ? and what kind of bhp did your cars get up to,once done ? |
Ive not had one done as a remap invalidates the warranty and although ive wanted one, i want my warranty more. I dont think it always invalidates your emissions, but that's a reason why LR's map is what it is, remember its a world market Mike 2014 Facelift Discovery |
No issue on the emissions for me. Just had the MOT done and it hardly registered |
I wouldnt expect any problem in the UK - the emission point is across each market and why LR have the map that they do, not how it affects your car ![]() 2014 Facelift Discovery |
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 ![]() ![]() ![]() |
If you use the site sponsor BAS then you get the ability to retune between factory standard and improved mapping anytime you want i.e. MOT/service time. RRS TDV8 (loving it)
Not in my case |
oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148 ![]() ![]() ![]() |
Had my 05 plate TDV6 HSE remapped and it is well worth the money. More power, fantastic mid range acceleration improvement and better fuel economy.
If you use command shift to pull away just pop it into 1st gear and you will see it make a whole lot of difference but then don't forget to either pop it straight back into auto or use your command shift to go up your gears, if you use auto only to get away from a standing start it sets off in 2nd gear hence the slow get away ![]() |
I think that is the great thing about the new 8 speed gear box, it pulls straight from the moment you put your foot down. ![]() I would love to get a remap and have been looking recently at an AmD one, but although my heart says yes, the heads saying no as I don't want to screw up the LR warranty. ![]() If I went for one of these changeable (eg BAS) maps, is there any way that LR can see you've had one installed, is there any log of the data etc. I'm not very good on the technical side of things ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
There isn't a changeable remap for the 3.0, only other way i guess is to have a second ecu. ![]() |
Thanks Ady, I think for the time being then I'll live with it as standard ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
I use command shift to select 1st at junctions quite often. Makes a huge difference. As one often needs to accelerate meaningfully in such situations, I often just let it change up automatically to 2nd and 3rd. This does require using the full rev range though ![]() ![]() 2008 TDV8 - it was a labour of love and is much missed |
