![]() | Home > Technical > Active corning on a 2008 to 2010 conversion - dash error. |
jundrill Member Since: 18 May 2011 Location: Epping Posts: 64 ![]() ![]() ![]() |
Come on people, help please! |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
Your only hope on such an issue is Bobby........he appears occasionally. PM him to see if he can offer any advice, he's the Encyclopedic of Land Rover things. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Is his user name just Bobby? Thanks. |
Yes. Search for authors under search and he will be there! |
THis could be anything - even that the new lights arent compatible with the old system! but check the obvious first, connections, resetting etc Mike
I have no idea what could be wrong, sorry.
So, did you get this sorted? Malaysia Boleh!
I'm still investigating (and I had a nasty red fault come up on the dash to do with the suspension which I've been focusing on for the past few days although its fixed now).
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
These 2 sentences should not be seen together ![]() |
It begs the question... doesn't it? |
I'm not doing it, a garage is on my behalf!! |
The error on the dash - what does your manual say? Anything to do with fog lamps? Malaysia Boleh!
