Home > General > Suspension light |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
check the power steering fluid mate, the antiroll bar is hydraulic and when its low on fluid it brings the light on when cornering usually |
Mon Oct 31 2011 7:33pm |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 61 |
Fluids to the top mark
Tue Nov 01 2011 9:29am |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
height sensor/chaffed loom issue?
Tue Nov 01 2011 10:04am |
yeah i was going to say that next
Tue Nov 01 2011 11:09am |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 |
I checked this on mine this morning due to having the suspension light on intermittently.
Sun Nov 06 2011 7:32pm |
yeah mate sounds like it, could be a broken wire given that its the two of them, common issue on the FFRR less so on the RRS so u might be lucky, sensors are only 35quid each
Sun Nov 06 2011 8:18pm |
richyrich70 Member Since: 04 Nov 2011 Location: Cheltenham Posts: 28 |
The light on mine comes on occasionally, when it does it's usually 30 seconds after the car has been started. It hasn't come on at all today! Strange. |
Wed Nov 09 2011 5:07pm |
jed.w Member Since: 02 Jan 2011 Location: West Lancashire Posts: 191 |
I got this about a month ago, took to specialist and they changed the air compressor. He said it was a common fault as the piston is so weak and thin. If it goes it can give false readings off the sensors.
Wed Nov 09 2011 8:13pm |
well my car has been plugged in and it turns out the air compressor needs replacing. Ouch. |
Fri Nov 11 2011 5:12pm |
Mine cost £630.00 SDV6 HSE Sport2 - Santorini Black, Ebony Interior, Pano Roof, Things I haven't found yet!
Fri Nov 11 2011 6:01pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
My car just came back from the Dealers yesterday, this lunchtime driving back to site after a short stop, flashing red suspension light and associated message.
Sun Nov 13 2011 9:40am |
Decided to go to stealers
Sun Nov 13 2011 3:43pm |
peterdalkey Member Since: 16 Feb 2013 Location: Dublin Posts: 2 |
I had the yellow suspension warning light coming on within half a mile of starting off, plus " normal height only" in
Sat Feb 16 2013 4:49pm |
57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113 |
I had the fault once after playing around with the suspension after 1 week of ownership (the car had been pretty much unmoved in 2/3months at the dealer I got it from. Now seems OK, guy at Guava reckons valves can become sticky if not used, haven't had the fault since... |
Sat Feb 16 2013 5:07pm |
