![]() | Home > General > Suspension light |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
check the power steering fluid mate, the antiroll bar is hydraulic and when its low on fluid it brings the light on when cornering usually |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 61 ![]() ![]() |
Fluids to the top mark
height sensor/chaffed loom issue?
yeah i was going to say that next
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
I checked this on mine this morning due to having the suspension light on intermittently.
yeah mate sounds like it, could be a broken wire given that its the two of them, common issue on the FFRR less so on the RRS so u might be lucky, sensors are only 35quid each
richyrich70 Member Since: 04 Nov 2011 Location: Cheltenham Posts: 28 ![]() ![]() |
The light on mine comes on occasionally, when it does it's usually 30 seconds after the car has been started. It hasn't come on at all today! Strange. |
jed.w Member Since: 02 Jan 2011 Location: West Lancashire Posts: 191 ![]() ![]() |
I got this about a month ago, took to specialist and they changed the air compressor. He said it was a common fault as the piston is so weak and thin. If it goes it can give false readings off the sensors.
well my car has been plugged in and it turns out the air compressor needs replacing. Ouch. |
Mine cost £630.00 |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
My car just came back from the Dealers yesterday, this lunchtime driving back to site after a short stop, flashing red suspension light and associated message.
Decided to go to stealers
peterdalkey Member Since: 16 Feb 2013 Location: Dublin Posts: 2 ![]() ![]() |
I had the yellow suspension warning light coming on within half a mile of starting off, plus " normal height only" in
57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113 ![]() ![]() |
I had the fault once after playing around with the suspension after 1 week of ownership (the car had been pretty much unmoved in 2/3months at the dealer I got it from. Now seems OK, guy at Guava reckons valves can become sticky if not used, haven't had the fault since... |
