Home > General > wanted, set of 19's / 20's
madkoka
Hi all, anyone got a old set of 19 or 20 alloys going, need a set for winter.
Post #316699 Sun Oct 09 2011 4:26pm
caperbility
United Kingdom 2005 Range Rover Sport Supercharged HSE Java Black
Ive got a set of 18s on fleabay at the moment if they are any good to you.
Not sure on the fitment though as they were off a 2003 vogue,you would have to check.
Item number eBay Item No. 270829793728
[/b]
Post #316711 Sun Oct 09 2011 5:36pm
Just picked up a set of 4 19inch via ebay. Been quite a lot on there recently. 2012 SDV6 - it's missing a couple of cylinders
Post #316712 Sun Oct 09 2011 5:43pm
madkoka
Just had a look on flebay Rolling Eyes seen a couple of sets, depends if the start going for silly money. Caperbility, 18s are two small to fit over Brembo's, thanks anyway. Very Happy
Post #316713 Sun Oct 09 2011 5:50pm
caperbility
No problem thanks for the advice Thumbs Up
Post #316714 Sun Oct 09 2011 5:56pm
smoftah
United Kingdom 2005 Range Rover Sport TDV6 HSE Stornoway Grey
Hi I have a set of 19" wheels that came off my car sitting in the garage that are for sale. 1 Wheel needs a tyre as it is below the minimum 1.6mm on the edges, the other 3 tyres still have plenty of tread.
All the wheels are in good condition from what I remember with no kerbing but I can confirm and send you pics tomorrow.
PM me an offer if you are interested and I can get you some pics tomorrow. Thumbs Up
Post #316715 Sun Oct 09 2011 6:10pm
Depends on what you consider silly money I guess Wink . I paid 450 for 4 wheels with pretty decent tyres too. 2 of the rims are totally unmarked, 1 has a slight mark and 1 has a kerbing graze which isn't too big. 2 of the tyres look to be only a few thousand miles old, the other 2 have plenty of life left too.
I might run these tyres next spring just to use them up rather than bin them. That means that I should be able to go for quite some time without buying new tyres - 1 set of 20s with decent life tyres, 1 set of 19 summer tyres of reasonable life and whatever set of winter/light mud tyre I get in the next week or two. 2012 SDV6 - it's missing a couple of cylinders
Post #316738 Sun Oct 09 2011 9:51pm
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
Pm sent.
Post #316759 Mon Oct 10 2011 7:13am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
I had 4 19" wheels with MTR rubber that was essentially brand new, for £875. I think I got them from this board actually in March 2010. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #316767 Mon Oct 10 2011 7:44am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I've got these 19" spare 2 have tyres that have done 150miles.
Post #316821 Mon Oct 10 2011 1:29pm
rrsboy
maybe James LPR can clarify but there is a check you need to do for 19s on the RRS, something to do with brake caliper clearance? ============
Post #316824 Mon Oct 10 2011 1:46pm
madkoka
I've emailed LPR just to make sure they will fit to MY2012
Post #316847 Mon Oct 10 2011 4:27pm
Tim in Scotland
No need to contact James, there are stacks of posts here about it with regard to PRE 2010MY cars and some for post 2010MY:
Basically if you have a pre2010MY RRS with Brembo brake callipers then the SMALLEST OEM wheel you can fit is the 5 x V spoke 19" wheel shown in MrFixit's photo. If you are happy to go aftermarket then there is a special design of Compomotive 18" wheel that isn't available in the UK, although it was designed especially for the Bowler Nemisis - see the posts recently by Flydive who has them on his car for the winter BUT if you have Brembo callipers then you still have to turn the resonator weights on the them through 180 degrees to have enough clearance. There is only one other OEM 19" wheel, from the D3 HSE (note D3 not D4), that will fit over the brakes. If you can find a 20" snow and ice tyre (I think Pirelli or Continental now sells one) then you can find any OEM 20" wheel over the brembos.
Sorry I cannot help with post 2010MY cars 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #316848 Mon Oct 10 2011 4:34pm
madkoka
Cheers Thumbs Up these will be for a MY2012
Post #316852 Mon Oct 10 2011 5:03pm
rrsboy
there is something else.. which James knows because he was their when we blew up one of my 19's.. two 19" wheels might appear to be identical, but one design has a slightly different internal 'slant' that in turn fowls the brake calliper. James - where are you!!!?!!!?! Big Cry ============
Post #316858 Mon Oct 10 2011 5:18pm
