Home > Technical > Unwanted Software Update? MY10 TDV6
NightFox
I've just picked up my RRS back from the dealer's after having a faulty oil sensor replaced. Got home, closed the car with the windows open and held down the 'lock' button to close the windows. Nothing happened. Got back into car to close them manually, only to find that the one-touch close no longer worked on any of the windows.
There doesn't seem to be a user setting for this, so I'm worried now that the dealers have also taken the opportunity to update the software, and this has included disabling the one-shot close and closing the windows via the remote. Does anyone know if LR has disabled this in the latest UK spec? I could ring the dealer but it seems to take about 2-3 days and as many attempts before they return my calls.
I'll be well pi**ed off if they have - this isn't ridiculously litigious America; it's sensible old Blighty where common sense still comes into it, and so far my daughters have both survived to the ripe old ages of 7 and 10 without accidentally decapitating or strangling themselves whilst closing the car windows.
Please tell me I've just missed a setting somewhere! Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #315605 Thu Sep 29 2011 3:46pm
it may just need resetting.
on the FL2 you hold the up button till the window close, and keep it held for a little while and you'll hear a click to say its done,
one touch windows should then work, repeat on each window.
then try the Lock function again
Post #315606 Thu Sep 29 2011 3:50pm
Tail End Charlie
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Re-calibrating the windows is detailed in the manual.
Post #315607 Thu Sep 29 2011 3:56pm
mse
All the functions remain on the 2011my Mike
2014 Facelift Discovery
Post #315631 Thu Sep 29 2011 6:44pm
NightFox
Ah yes, windows recalibrated and back to behaving as they should.
Valium back in bottle, foam wiped away from mouth Embarassed
Thanks for the replies! Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Post #315766 Fri Sep 30 2011 11:35am
