Home > Technical > Creaking when Lowering/Raising |
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 |
It's normal, most do it. Or when it lowers slightly when you lock it up..... |
Thu Sep 22 2011 7:26pm |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
Is it? Mine doesnt do it. Could it be the bushers ? |
Thu Sep 22 2011 7:28pm |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 |
Yes mine does after I lock up. It's like it's farting, funny. |
Thu Sep 22 2011 8:48pm |
Are you sure that isn't you |
Thu Sep 22 2011 8:55pm |
Well now that you mention it I do like beans ady. Well that's sorted then. Perfect |
Thu Sep 22 2011 8:59pm |
KVT84 Member Since: 22 Sep 2011 Location: Calgary, Canada Posts: 2 |
The creaking was occurring while the RRS was in park/brakes applied...I've been reading some posts that seem to suggest it isn't wise to change to access mode when in park (instead it should be done when in motion)...is there any truth to this? Was the creaking a result of me changing to access mode when in park? |
Thu Sep 22 2011 10:14pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
I rarely use access mode and the only time I've heard a creaking noise is when I have used it (to help aged rellies getting /out of the back seats). Most likely it's because the geometery changes with suspension movement and you've effectively locked one end of the car with the park brake. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Sep 22 2011 10:20pm |
