![]() | Home > Tips & Tricks > All 4 window open/close control |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Not sure if it's just me that didn't know this but picked it up of the Disco site today.
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
It's called global opening............. usually in "menu's" quite old hat actually |
Did you know that when your motor goes in for service they also update the hard drive for the sat nav |
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
What are the options on the key openeing etc, I have tried them after having the facility on th x5 but seems not to work, can anyone elaborate please? Cheers Tim |
Its only on the newer models tim ![]() |
Ahh but what update??! Mike 2014 Facelift Discovery |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 ![]() ![]() |
... an upgrade to the new MY2012 standard would really be something SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
Any new roads/locations or software ![]() |
im with you on that - i heard again the rumour of an allegiance upgrade Mike 2014 Facelift Discovery |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
No I did not know this! thanks ![]() |
Perhaps us bloke ought to do the unheard of once in a while and RTFM !!!! ???
I can just picture you sat in your office looking out of your window, press to open.... Press to close... Press to open... Press to close ![]() |
It certainly grabs peoples attention on a busy street, bit like activating the headlights when the neighbours take their bin out |
But did you also know that if you have Park Heat you can also use it as Park Cooling on hot days? It uses it's thermostat to sense the ambient temperature and if it is above the threshold it will run a cooling fan instead of the FBH. You can set it from the screen as well as the remote. On my car it will run for up to 20 minutes then shut down, it won't start if it sense the battery charge is low as well. So no need for undignified 4 window opening on a hot day, just go to the office window and aim the Park Heat remote at the car and start it 20 minutes before you want to drive off i you nice cooled car - RTFM! A bonus is that while the car is cooling all the doors are still locked and the windows are closed 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
