Home > Tips & Tricks > All 4 window open/close control
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
The bottom button on the remote used to unlock the whole tailgate, but now all of a sudden it only unlocks the top half. I can't see how to get it back to unlocking the whole tailgate..
Post #311284 Wed Aug 24 2011 12:40pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
oooh i have a 05 rrs mine dont do that, how do i make that work Smile its a pain in the bottom when you get out and realsie a window is open.............
Post #311308 Wed Aug 24 2011 2:23pm
mse
You programme is - i think from memory press the remote and the boot section button you want to unlock at the same time Mike
2014 Facelift Discovery
Post #311341 Wed Aug 24 2011 4:43pm
peanutbob
Mse, I tried that thanks...but it doesn't change anything, the top still unlocks with the remote but not the whole t/gate.
Thanks anyway!
Post #311512 Thu Aug 25 2011 1:10pm
happs
2005 Range Rover Sport TDV6 HSE Java Black
Does the global opening work on my 55 reg rrs?
Post #354319 Tue Aug 21 2012 11:13am
Kiwi Graham
New Zealand 2007 Range Rover Sport TDV6 SE Stornoway Grey
I understand if (whilst still in bed) you push all thre buttons the car will start and drive its self to a pre determined point via the sat nav (work for instance) giving the workplace the impression you are actually at work and again at a pre determined time return home.
I guess if you drill down through the menues you could select radio stations and climate controle settings for the occupant-less car to have running.
What ever happened to turning a key to open a door and winding down the window to get fresh air, progress aye Wink
Post #354405 Tue Aug 21 2012 11:10pm
