Home > Technical > Side mirror vibrating while driving, any ideas how to fix?
Frosty_Power
Canada 2006 Range Rover Sport 4.4 V8 HSE Alaska White
Hi there, have a small issue(I think) on the wife's '06 RRS. When driving the drivers side mirror vibrates like it is not tight. It's not the whole assembly but the actual glass mirror. So when I drive it, looking at it, it is shaking all the time, especially on the highway. Any ideas how i can tighten this thing? I'm hoping I can do it without having to take the whole mirror assembly out.
Thanks in advance.
Post #301048 Sat May 28 2011 4:08am
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
sounds like its not clipped in properly..have you tried small amount of pressure to see if it locked in place
Post #301082 Sat May 28 2011 12:50pm
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
Re: Side mirror vibrating while driving, any ideas how to fi
Thanks in advance.
Mine was doing the same thing, pull the glass off and see if any of the screws that hold motor mechanism are loose. I tightened mine and it's solid as a rock now.
Post #302417 Thu Jun 09 2011 3:59pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
good point, the mirror is simply clipped into a plastic holder Vadim A.
Post #302468 Thu Jun 09 2011 11:01pm
