Home > Technical > Steering vibrations |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
In response to the question of this topic - steering/vibrations & sensation of slight knock through the steering column = I have been experiencing the very same thing & as we speak my RRS is at the dealer being fixed. I have had to wait for some new parts that LR have finally developed/produced as they were aware of this problem & have been busy trying to sort ASAP. I only got the call last week that LR had finally released the parts to solve this common problem. I will report back later when I know more
Wed May 03 2006 1:58pm |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 |
.. am looking forward to hearing from you. Have the same slight knock at low speed through the steering column. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
Wed May 03 2006 2:44pm |
BBlackRRS Member Since: 31 Aug 2005 Location: US Posts: 40 |
MDP, please do keep us updated on this new "fix". I have already had my steering rack replaced, which helped a bunch. But whenever I floor the gas, the steering wheel still shakes. I also get knocking and some louder suspension creaks when I am going very slow. Interested to hear what they now have to hopefully solve this issue.
Wed May 03 2006 9:37pm |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
Following taken from a post on Disco3.co.uk and is exactly what I am experiencing on my vehicle.
Thu May 04 2006 6:52am |
You beet me to it Smarticus
Thu May 04 2006 8:25am |
MDP, how about high speed take offs? Did you ever get vibrations through the wheel if you floored the gas? Also, how about highway passing speeds if you were to floor it as well? Besides the knocking of course.
Fri May 05 2006 8:55am |
...as expected my dealer, which happens to be the major LR dealer in Switzerland, kew nothing about that technical bulletin regarding steering knock.
Sat May 06 2006 3:57am |
Seems like a few owners are getting this issue fixed at the moment as LR have run out of parts needed ... Following is the email from my dealer on this matter :
Tue May 09 2006 9:16pm |
MDP, care to give us an update on this repair, has it solved both problems??? |
Tue May 16 2006 8:14pm |
sadly not.
Tue May 16 2006 10:52pm |
Wed May 17 2006 4:47am |
My car went in for the steering fix but sadly the problem is still there. A light knocking at the front end on mildly uneven road surfaces, especially when going down hill. Feels like a loose ball joint or too much play in some suspension or steering component. It falls into the mildly annoying category - although you have to wonder if there may be safety implications if something is loose.....
Thu Jun 08 2006 8:35pm |
texas911 Member Since: 02 Jun 2006 Location: Houston, Texas Posts: 31 |
That's BS about the hammer on type weights for the wheels. My RRS has stick on weights inside the rims. Obviously your dealer doesn't have the stick on weights and is feeding you a load of bull. 2006 RRS Silver/Black |
Thu Jun 08 2006 9:23pm |
Tend to agree on the weights thing - This knock etc is nothing to do with wheel balancing. It is definately a steering column/shaft related problem.
Fri Jun 09 2006 10:40am |
