Home > Technical > Does the auto box learn driving style
AIAW
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
I once read in another forum that you can reset the information that the computer has obtained from your driving style. It has worked for other car owners (Jaguars and BMWs).
I am not sure if it will work on the Range rover sport but it is worth a try as it.
Here is how to do it.
Turn the ignition switch to 2 so that the electrics are on but the engine is not started
Press the brake pedal firmly for 40 seconds
Turn the ignition off and start the engine.
The system should reset itself and adapt itself to your driving style.
Post #313784 Thu Sep 15 2011 1:57pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Now thats interesting!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #313792 Thu Sep 15 2011 2:56pm
mse
Not if you dont have a key Rolling Eyes Mike
2014 Facelift Discovery
Post #313809 Thu Sep 15 2011 5:09pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
On my TDV8 with the double epic grin factor, to overtake I just throw the stick into command shift and whooosh...! First time I did that the car in front seemed to be reversing swiftly. Anyway,it gets me to the next fuel stop in no time at all.
Post #313849 Thu Sep 15 2011 9:59pm
ELD70
I thought to reset the gearbox settings, disconnect battery and touch the leads together?
Post #313856 Thu Sep 15 2011 10:37pm
peanutbob
That's for Nissan Micras.... Laughing Laughing
Post #313865 Thu Sep 15 2011 10:56pm
AIAW
[quote="mse"][quote="Steuart64"][quote="AIAW"]I once read in another forum that you can reset the information that the computer has obtained from your driving style. It has worked for other car owners (Jaguars and BMWs).
The system should reset itself and adapt itself to your driving style.[/quote]
Now thats interesting!![/quote]
Not if you dont have a key Rolling Eyes[/quote]
I Think for the newer models that are keyless go, you just set the turn on the system without turning on the engine. Im not too sure whether this will work on a Range rover but it has certainly worked on Jaguars and BMWs (looking at other forums)
Post #313971 Sat Sep 17 2011 2:49am
Yeah, works for me. Just knock the lever across in to sport, the box always changes down to give c.2k revs and then I press the pedal. And then she just, well, goes! Very Happy 2012 SDV6 - it's missing a couple of cylinders
Post #313976 Sat Sep 17 2011 8:41am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
i reckon my old 2.7 must have been a slow learner Laughing the 5 years i had it was quite predictable, whereas the new 3 litre gear selection is driving me manic Evil or Very Mad continues to hold gear for far to long, or coming out of a roundabout or after slowing down it cannot find the right gear quick enough, i usually have to over ride it with command shift when its up at the 4K rev or practically ticking over at the other end of the scale and i need some horses applied... must have been decided to go with the wifes style i reckon rather than mine Whistle Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #313977 Sat Sep 17 2011 8:45am
