Home > Maintenance & Modifications > What size spare can I fit?
Money Money Money
2005 Range Rover Sport Supercharged Java Black
Hey Guys,
So I seem to be going through tyres pretty quickly at the mo, twice in 3 months I have had a puncture then either the same day or the next day the spare gets a puncture!
Anyway the 19" space savers buggared, every garage sayd they can't help, found a garage that fits tyres for Lancaster LandRover and they say they are on back order and not sure when they can get them, I have found a full size supercharge alloy with tyre for less then tehy will fit a tyre for (when they can get one) will the full size alloy fit under the car? - I'm sure it will as my old supercharge spare was identical except black...
Can anyone confirm please.
MMM
Post #300017 Fri May 20 2011 9:56am
mse
I dropped the 19" spare on my 2011 car and it looked tight - not sure you could get a 20" in but certainly not a 22"
Why not give it a go...only take 10 minutes. Mike
2014 Facelift Discovery
Post #300022 Fri May 20 2011 10:10am
Money Money Money
I thought my Supercharged has a 20"? They look the same but just black... anyone know.
I would try it but all 4 are on the car, and the 20" I would buy is on eBay!
ALSO - I'm in the process of fixing the cable lift that lowers and lifts the spare as some twonk broke it, probably that same twonk (AA Man) that jacked my car up on the compressor, LandRover have kindly provided me with a £656 quote to fix!
Post #300026 Fri May 20 2011 10:22am
mse
Yes they are all 20 - i was saying you may squeeze a 20" in but certainly not a 22" if there was any doubt!
If the winch is broken that would slow you down - i would have knocked one of the road wheels off the car and tried it - doesnt take many minutes...but i appreciate that isnt an option for you; will have to wait for someone who has tried it - it did seem very tight on the 19" though...certainly at the wheel/exhaust side. Mike
Post #300027 Fri May 20 2011 10:28am
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
Try this http://cgi.ebay.co.uk/Rangerover-Sport-Dis...4156ae4d79
Thumbs Up 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #300029 Fri May 20 2011 10:29am
Money Money Money
Yeah saw that mate - Thanks, saved £90 though drilling the rivets, fixing the cable then sticking some flat headed bolts in to hold it all back together. - Just got to get round to fixing it back on.
Just need someone to confirm that you can fit a 20" spare wheel under the car.
MMM
Post #300030 Fri May 20 2011 10:32am
Money Money Money
Ah, maybe the old (Black) Spare was 19"????..... http://cgi.ebay.co.uk/Range-rover-sport-sp...500wt_1156
Post #300032 Fri May 20 2011 10:34am
barry15555
MMM
When i had a puncture i put the flat one under the car no problem. (20") 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #300033 Fri May 20 2011 10:37am
Money Money Money
MMM
Ha ha ha... yeah so I have, many times! - What a bloody idiot!
Thank you for pointing that out! Rolling with laughter Bow down
I can't believe I didn't think of that!
Move along, nothing to see here.
Post #300034 Fri May 20 2011 10:41am
barry15555
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up Thumbs Up 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #300035 Fri May 20 2011 10:43am
mse
Good point Thumbs Up especially as the low profile tyres dont deflate too much to not fit! Mike
Post #300039 Fri May 20 2011 11:43am
drdelrrs
As the diameter of the wheel increases the profile of the tyre decreases so you end up with an overall outside diameter that's the same - other wise the speedometer,sta nav etc would all neeed recoding when LR fited different wheel/tyre options.
So if the 19 with high profile normal fits so will a 22inch with a low profile.
Post #300063 Fri May 20 2011 4:45pm
mse
whilst that is true to a point, you do recallibrate for the different tyre sizes Thumbs Up there are options to set the tyre size to adjust the speed.
In the old days that was a different gear, but now its a option in one of the ECU's Mike
Post #300066 Fri May 20 2011 5:14pm
JASONC
England 2006 Range Rover Sport TDV6 HSE Santorini Black
i have a 10"x22" 285/35x22 spare fitted for over 2 years now no problems Thumbs Up
Post #300084 Fri May 20 2011 9:19pm
