Home > General > Auto locking
timcom0
mse wrote:
ChrisP wrote:
Just to clarify,if all 4 doors are locked but the tailgate is open with the key inside and you then shut the boot it will lock because thats what I did Big Cry
That is correct - the boot isnt part of the main doors when the car is locked...open a door first
That was the same on my 1967 Morris Minor, if i opened the boot while the car was locked then put the keys in the open boot and shut it, DOH locked out, not rocket science don't put keys in a locked car,lol
Post #299409 Fri May 13 2011 6:36pm
ChrisP
It might not be rocket science but when you get to my age not much is,keep leaving my keyless go key in the car and can't work out why it won't lock. Whistle MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #299411 Fri May 13 2011 6:52pm
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
I just pressed the unlock button of my remote, then without opening a door, Opened the tailgate, Then shut it,Waited 3 minutes then tried Drivers door and it opened. 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #299412 Fri May 13 2011 6:57pm
ChrisP
I agree but that only works if all 4 doors are unlocked,I had locked the doors(don't know why) and was sat in the boot taking my wellies off,left the key in the boot and shut the tailgate which immediately locked itself. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #299413 Fri May 13 2011 7:05pm
barry15555
Your right Chris, Just did what you said,But my horn sounded to tell me that the tailgate was open when i pressed the lock button. 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #299416 Fri May 13 2011 7:23pm
SVR575
keyless cars , the doors lock automatically and car shuts down, but if you have not pressed the door to lock it and go to open the car with out the key fob the alarm will go. So basically you can not leave car open unless you leave the key in side the car, in which case you can not lock it any way! Confused? SVR 2018 in Santorini Black.
Post #299546 Sun May 15 2011 7:55pm
