Home > Technical > TDV8 - Stuttering / Mis-fire Engine - DTC Code P02B4 / U0402
Linko
Help!
Over the last couple of days my car has been stuttering when I am doing around 30mph and around 2000rpm as if it's struggling a little.
I've been able to connect to the OBD-II port and check for error codes, which are:
    P02B4 - Cylinder 7 - Injector Restricted
    U0402 - Invalid Data Received From TCM (Transmission Control Module)
Anybody had this experience? Are the 2 codes linked?
Is it possible to check the injector and clean or should I play safe and take it to the dealer?
Cheers,
Mark
Post #299023 Wed May 11 2011 11:33am
not linked I'd say.
Mine had the U0402 error a while back, turned out to be tracking linked.
Your misfire is more likely the injector issue. RRS gone
Post #299026 Wed May 11 2011 12:05pm
Linko
An update for anyone that happens to run in to the same problem.
Regarding the P02B4 Injector Restricted code. The injector was replaced and it didn't make a blind bit of difference. the car still felt like it mis-fired around the 2000rpm point when under accelaration.
Took the car back and had a... 'discussion' with the dealer principle! He gave me a courtesy car and promised to get it sorted. A week later... yes a WEEK later I was told it seems that the Torque Converter in the auto box was slipping. Told about a double flush which has a 90% chance of success or new torque converter at £900 + VAT & +Labour.
Went for the double flush, with an addative to help lubricate the torque converter. I have seen (thanks to SRE) this http://www.disco3.co.uk/forum/topic47485.html thread from the Disco3 site. The symptoms seem exactly the same as what i've been suffering.
Picked the car up today and was told that I may still notice the 'judder' for the next 100 to 150 miles whilst the additive gets to work. Fingers crossed!
Post #302055 Mon Jun 06 2011 8:18pm
gazellio
Any update?
Post #452504 Sat Feb 14 2015 3:51pm
Bodsy
Site Sponsor
I know linko sold it since, but he also had replacement torque converter as it didn't fix the issue. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #452505 Sat Feb 14 2015 4:16pm
Linko
Yeah... As Bodsy said the flush didn't fix it. In the end the torque converter was replaced and a load of other stuff as it a glycol leak from the radiator.
It was about £2.5k in the end. Fortunately it was taken care of by the warranty and some negotiation with the Service Manager.
Post #452528 Sat Feb 14 2015 8:23pm
