Home > Maintenance & Modifications > Vibrating Steering Wheel |
Its a good chance its just the wheels that need balancing, |
Sun Apr 10 2011 9:24pm |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 |
SWMBO hasn't curbed it has she?
Sun Apr 10 2011 9:39pm |
Im hoping it is the balance...ill have to ring the dealer tomorrow.
Sun Apr 10 2011 11:57pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Wheel balance, steering rack, shafts or diffs....could be any of them. |
Mon Apr 11 2011 2:18am |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
There is a fix that has worked for some that is the 25 Kilos of front axle weights they strap on , also known as a bodge fix. They tried new wheels , new ball joints , new rack,new column new bushes,released the whole front engine mounts and suspension and torqued back up still no joy. 2014 5.0SC AB
Mon Apr 11 2011 6:40am |
I need to run a test tomorrow but it seems not to have been there on both todays journies by difference in tyre pressures
Mon Apr 11 2011 3:54pm |
Have you driven through any mud recently? If you have and you haven't taken the wheels off since it is possible you can have hardened on mud at the back of the spokes that can put the wheels severely out of balance as it acts as additional balance weights 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Apr 11 2011 4:26pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
hello bud
Mon Apr 11 2011 4:34pm |
Apart from the obvious wheel balancing etc they guys have mentioned you might check the circumstances.
Mon Apr 11 2011 6:20pm |
Some good suggestions here - thanks guys
Mon Apr 11 2011 6:51pm |
hello mse
Mon Apr 11 2011 8:21pm |
Thanks I'll keep it in mind Mike 2014 Facelift Discovery |
Mon Apr 11 2011 8:23pm |
JazzyJeff Member Since: 03 Apr 2012 Location: Leeds Posts: 4 |
I have a 2009 RRS HSE - purchased only 5 months ago - initially the wobble over 70 mph was awful. And from early morning start - the wobble at 60 mph is not good.
Tue Apr 03 2012 9:06am |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 |
I had similar problems with my MY06, irrespective of Steering wheel changes. Bushes, rehydration front diff changes etc etc, the LR dealership could not pin it down. My friendly LR independent who was servicing the vehicle noticed a slight difference in the tread pattern on the front tyres although both were Goodyear Wranglers.. one had more grip (on road) than the other, so basically caused more bias in terms of direction and consequently the steering wheel to vibrate.... Assuming you have discounted the tyres, then in true Land Rover sense no doubt they will go through a series of elimination based upon changing components until they fix it OR NOT...
Tue Apr 03 2012 10:18am |
