![]() | Home > Maintenance & Modifications > Vibrating Steering Wheel |
Its a good chance its just the wheels that need balancing, |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
SWMBO hasn't curbed it has she?
Im hoping it is the balance...ill have to ring the dealer tomorrow.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Wheel balance, steering rack, shafts or diffs....could be any of them. |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 ![]() ![]() |
There is a fix that has worked for some that is the 25 Kilos of front axle weights they strap on , also known as a bodge fix. They tried new wheels , new ball joints , new rack,new column new bushes,released the whole front engine mounts and suspension and torqued back up still no joy. 2014 5.0SC AB
I need to run a test tomorrow but it seems not to have been there on both todays journies by difference in tyre pressures
Have you driven through any mud recently? If you have and you haven't taken the wheels off since it is possible you can have hardened on mud at the back of the spokes that can put the wheels severely out of balance as it acts as additional balance weights 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
hello bud
Apart from the obvious wheel balancing etc they guys have mentioned you might check the circumstances.
Some good suggestions here - thanks guys |
hello mse
Thanks I'll keep it in mind Mike 2014 Facelift Discovery |
JazzyJeff Member Since: 03 Apr 2012 Location: Leeds Posts: 4 ![]() ![]() ![]() |
I have a 2009 RRS HSE - purchased only 5 months ago - initially the wobble over 70 mph was awful. And from early morning start - the wobble at 60 mph is not good.
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
I had similar problems with my MY06, irrespective of Steering wheel changes. Bushes, rehydration |
