Home > Technical > How's your MAP sensor? |
m40cca Member Since: 04 Sep 2014 Location: leeds Posts: 89 |
thanks for that dsl just jumped outside removed mine and its full of gunk mines a 06 89k with egr removed but that was only done last month |
Sat Sep 13 2014 6:41pm |
rudadu Member Since: 12 Sep 2014 Location: Dunfermline, Fife Posts: 48 |
Thanks for the reply Somerset Bumpkin I'll give it som oomph tomorrow and see how it goes. No more pussyfooting |
Sun Sep 14 2014 6:58pm |
Thanks for replies. Eventually, got round to removing MAP sensor. Found it clean as a whistle Does anyone have any ideas what could be causing the blue exhaust smoke (only when accelerating hard). I've had my RRS for a couple of months now and loving it but the smoke is annoying . I'm up to some easy investigations but don't have facility or tools to "get stuck in" as it were Thanks in advance for any hints, tips or help. |
Mon Sep 22 2014 8:25pm |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 |
I want to check mine and clean as necessary and have looked at the disco3 forum but want to be sure I know what I am doing. From what I have read I take the oil filler cap off and then tug at the engine cover to remove it which gives me access to the MAP sensor. Is this correct? |
Tue Sep 23 2014 1:49pm |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
Yes that's right give it a good tug |
Tue Sep 23 2014 2:31pm |
Just checked mine and it was filthy. Now cleaned and hopefully that might help towards my pretty bad MPG. Great heads up post BTW. Just the sort of thing one joins the Forum for. Thanks.
Tue Sep 23 2014 2:47pm |
dotty Member Since: 11 Sep 2014 Location: St Heiler Posts: 52 |
Checked and cleaned mine today. As Nigel52 said 'Great heads up post' Thanks
Mon Oct 06 2014 8:28pm |
Jemmountford Member Since: 04 Oct 2014 Location: Warwickshire Posts: 20 |
Folks,
Tue Nov 25 2014 4:20pm |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
When Betsy was getting her remap the guy doing it cleaned mine out, and it was FULL of .
Wed Nov 26 2014 10:12pm |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
took mine out and cleaned it (quite filthy with just a tiny hole thru the crud) as Jem said, a bit of hunting on tickover just after startup seeems to have gone now, easy job |
Thu Nov 27 2014 7:14pm |
Wee update.. Been keeping an eye exhaust smoke over passed months and seems to have disappeared under hard acceleration Don't know why but all seems well. Maybe needed time to clear out accumulated soot/crud/whatever?? Haven't done anything but have been on M8 a lot in recent weeks/months maybe that helped.. This is a cracking RRS forum guys.. really glad I joined up. Hints and tips and other info very helpful. Cheers. |
Sat Dec 06 2014 2:49pm |
Range_Driver Member Since: 12 Aug 2014 Location: Stockholm Posts: 4 |
Hi guys,
Sun Jan 25 2015 1:27pm |
Update!
Sun Jan 25 2015 1:42pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Heres my Map sensor from todays clean. No problems before, just thought I'd check it anyway. It was a bit groggy but haven't noticed many more MPG's or anything than some people report on.
Sun Feb 15 2015 12:05am |
