Home > Technical > Slight Vibration/noisy gearbox
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi all. Had a transmission oil change & update done on RRs cos of slight shunt in drive train Which has done the job glad to say... But i have noticed a bit of a noise from the transmission wnen in 2/3/4 ithink. it happens at 2000 revs then after that its quite again its hard to explain the noise is a bit like a vibration noise nothing seems loose Anyone have any ideas Exclamation Confused
Post #295108 Tue Apr 05 2011 5:09pm
Simon_scott_wilson
United Kingdom 2008 Range Rover Sport TDV6 HSE Izmir Blue
Hi. Did you ever get a resolution to this?.......I have the same issue on mine. Newbie
Post #401101 Mon Nov 04 2013 8:37pm
highfellzippy
Try dr tranny off ebay £8 a tube
2 tubes straight into gearbox done a sport and disco 3. This week massive difference
Post #405149 Fri Dec 06 2013 9:38pm
shadrack
i had similar and solved with dr tranny
Post #405184 Sat Dec 07 2013 8:28am
