Home > Technical > Slight Vibration/noisy gearbox |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 |
Hi all. Had a transmission oil change & update done on RRs cos of slight shunt in drive train Which has done the job glad to say... But i have noticed a bit of a noise from the transmission wnen in 2/3/4 ithink. it happens at 2000 revs then after that its quite again its hard to explain the noise is a bit like a vibration noise nothing seems loose Anyone have any ideas |
Tue Apr 05 2011 5:09pm |
Simon_scott_wilson Member Since: 18 May 2013 Location: Worcester Posts: 8 |
Hi. Did you ever get a resolution to this?.......I have the same issue on mine. Newbie |
Mon Nov 04 2013 8:37pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
i had similar and solved with dr tranny |
Sat Dec 07 2013 8:28am |
