Home > Technical > Drive mode |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
What exactly do you mean? Does the car drive whilst in D but you have no control over the gearshifts? That is normal - part of the 'automatic'
Wed Mar 23 2011 9:20am |
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 |
I think what he is trying to say tis that the car stays in 1st gear on the auto bit and revs the balls off the car. Is this correct? |
Wed Mar 23 2011 12:41pm |
Thats it foxy, straight to the point thats how i read it too. |
Wed Mar 23 2011 12:52pm |
Im practically a qualified LR technician...All im short of is the uniform..... |
Wed Mar 23 2011 12:54pm |
Lets not go there |
Wed Mar 23 2011 12:56pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Lets do go there |
Wed Mar 23 2011 2:58pm |
From reading the original post I thought I would clarify if the car actually moves, if the gearbox is shifting when in M/S then it can move, the original post does not state if the car actually moves when in Drive/is stuck in 1st or 2nd? I would think that if the car is changing gear normally when in M/S it should change in Drive as the controller for the gearbox is the same in both modes no? |
Wed Mar 23 2011 3:34pm |
tony harker Member Since: 21 Mar 2011 Location: middlesbrough Posts: 21 |
yes it will not change gear just revs the balls off it .the dynamic response light is on amber and the dynamiic stability control amber and the brake systems amber .when i turn the ignition off the engine was still running for about 5 seconds then cut out . |
Wed Mar 23 2011 10:10pm |
Sounds like an expensive trip to the stealers is in order
Wed Mar 23 2011 10:15pm |
yes mate it drives but have to change it to m/s mode to change gear |
Wed Mar 23 2011 10:29pm |
just hope its a spark plug |
Wed Mar 23 2011 11:14pm |
Thu Mar 24 2011 9:38am |
Thu Mar 24 2011 8:30pm |
Any luck yet ? |
Thu Mar 24 2011 8:34pm |
