Home > Technical > Drive mode
Page 1 of 3 123>
tony harker
England 2005 Range Rover Sport TDV6 HST Arctic Frost
Drive mode
Can some one help my range rover sport 2006 won't automatic change gear when in drive . It will change when in m/s mode can anyone help
Post #293342 Wed Mar 23 2011 7:03am
simon1233
What exactly do you mean? Does the car drive whilst in D but you have no control over the gearshifts? That is normal - part of the 'automatic' Whistle
When you push the gear shifter to the left from D you go into an automatic sport mode which holds onto the revs a little longer and then shifts for you and if you pull or push the lever when it is to the left you have 'manual' control over which gear to use.
If the car doesn't drive whilst in D then this sounds like an expensive problem...
Post #293350 Wed Mar 23 2011 9:20am
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I think what he is trying to say tis that the car stays in 1st gear on the auto bit and revs the balls off the car. Is this correct? Smile
Post #293358 Wed Mar 23 2011 12:41pm
Thats it foxy, straight to the point Thumbs Up thats how i read it too.
Post #293360 Wed Mar 23 2011 12:52pm
Siberianfox
Im practically a qualified LR technician...All im short of is the uniform..... Smile
Post #293361 Wed Mar 23 2011 12:54pm
Lets not go there Rolling with laughter
Post #293362 Wed Mar 23 2011 12:56pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Quote:
Lets not go there
Lets do go there Exclamation Whistle Laughing
Post #293372 Wed Mar 23 2011 2:58pm
simon1233
From reading the original post I thought I would clarify if the car actually moves, if the gearbox is shifting when in M/S then it can move, the original post does not state if the car actually moves when in Drive/is stuck in 1st or 2nd? I would think that if the car is changing gear normally when in M/S it should change in Drive as the controller for the gearbox is the same in both modes no?
Post #293374 Wed Mar 23 2011 3:34pm
tony harker
yes it will not change gear just revs the balls off it .the dynamic response light is on amber and the dynamiic stability control amber and the brake systems amber .when i turn the ignition off the engine was still running for about 5 seconds then cut out . Big Cry
Post #293403 Wed Mar 23 2011 10:10pm
simon1233
Sounds like an expensive trip to the stealers is in order Big Cry Big Cry Big Cry
Possibly something has failed and it is in limp mode.
What I have learnt from 2 years of owning a RRS is that something as simple as a wiring fault causes all manner of faults as these cars are rammed full of technology.
Hopefully it is not anything too expensive
Post #293405 Wed Mar 23 2011 10:15pm
tony harker
yes mate it drives but have to change it to m/s mode to change gear
Post #293407 Wed Mar 23 2011 10:29pm
tony harker
just hope its a spark plug Razz
Post #293418 Wed Mar 23 2011 11:14pm
tony harker
Post #293451 Thu Mar 24 2011 9:38am
tony harker
tony harker wrote:
Post #293553 Thu Mar 24 2011 8:30pm
Siberianfox
Any luck yet ? Smile
Post #293556 Thu Mar 24 2011 8:34pm
Page 1 of 3 123>
