Home > General > WHICH TRANSMISSION OIL FOR AUTO GEARBOX? |
marksgd Member Since: 10 Oct 2010 Location: Worcestershire Posts: 68 |
illhave a look ta |
Tue Mar 22 2011 9:21pm |
Still cant find it |
Wed Mar 23 2011 5:58pm |
Can someone please explain in laymans terms how to use the search facility properly, everytime i try a search i get everything but what i'm searching for |
Thu Mar 24 2011 8:36am |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
same here |
Thu Mar 24 2011 3:34pm |
Hi all. Ok just changed the Transmission oil. The Land Rover Dealership told me on the phone that the transmission holds 9.5ltrs . Well i drained the oil out nowhere near 9ltrs came out ..I then refilled the box started the engine & went through the gears 3-4 times. Then drained all the oil back out I then refilled the transmission approx 2 ltrs on the second fill. Drove it home & at the moment no shunts the wife has drove it to worcester now so i will have a blast around town later to see if it has sorted it. Will let you know the outcome The total time from start to finish was 45mins |
Sat Mar 26 2011 1:54pm |
Which oil did you eventually use? |
Sat Mar 26 2011 2:39pm |
Millermatic ATF DM |
Sat Mar 26 2011 5:33pm |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
hi sorry guys martin hasnt replied back to me regarding how to put up that link i have in a pdf form
Sat Mar 26 2011 5:42pm |
Filled it up until the oil came out of the filler so fingers x.. Have just drove it & it still shunts but not as bad. |
Sat Mar 26 2011 5:48pm |
Ill live with it aint gonna bother to flush it again . will have to find out how to do the gearbox update Patch.. |
Sat Mar 26 2011 5:51pm |
Cheers |
Sat Mar 26 2011 8:28pm |
Ok Took the RRs into AllTrack 4x4 the bloke checked i had filled the transmission up properly. It was abit low!! anyway he done the latest transmission updates (Wendsday) Cost me £45.00 & it seems to be all ok |
Fri Apr 01 2011 3:13pm |
