Home > Technical > Please help identify this part - (pic)
LEESY
Hi
I have a mechanical knocking coming from the rear i think..... the only moving bits underneath are these 2 heavy rotating clumps of metal! see pick for where i THINK its knocking.
has anyone got any idea what they are ? (both situated next to both exhaust pipes).
Matt LEESY
Post #291179 Sat Mar 05 2011 5:05pm
ciaa
United Arab Emirates 2006 Range Rover Sport Supercharged Java Black
These are the 'Harmonic Mass Dampers'
There there to reduce vibrations through the car i believe... looks like ones come loose Wink 2006 RRS Supercharged
Hawke Saker 22" rims Nitto Tires
Larini exhaust System
ECU remap
Modified and ported supercharger with 3lb pulley
Post #291182 Sat Mar 05 2011 5:49pm
LEESY
both of them pivot and swing like elvis!
are they supposed to swing ?! LEESY
Post #291189 Sat Mar 05 2011 6:31pm
BulletProofBomb
Uh huh.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  RRS TDV8 (loving it)
Suzuki Bandit 1200 (For when the suns out)
Nissan 350z GONE
Post #291207 Sat Mar 05 2011 9:20pm
BulletProofBomb
Sorry, I've no idea but I couldnt resist.
Thank you very much. RRS TDV8 (loving it)
Nissan 350z GONE
Post #291208 Sat Mar 05 2011 9:21pm
td6006
2005 Range Rover Sport TDV6 HSE Zambezi Silver
knoking noise
HI MINE IS FITTED WITH THE SAME DAMPENNERS AND I HAD A KNOCKING NOISE FROM THE BACK SAME AS YOU AND TO BE HONEST I THOUGHT IT WAS COMING FROM THESE, BUT AFTER TAKING TO A MATE WHO IS A TOP MECHANIC, ONE LOOK AND TOLD ME IT WAS REAR ANTI ROLL BAR BUSHES.TOOK TO MAIN DEALERS HAD CHANGED PROBLEM SOLVED. I THINK IT COST ABOUT £109 SO NOT THAT BAD. HOPE IT HELPS REGARDS TD6 Thumbs Up 2005 HSE 2.7 RRSport loaded with 2010 goodies
GONE
2005 FFRR VOUGE SE
2008 FACTORY HST RRS
Post #291210 Sat Mar 05 2011 9:35pm
LEESY
Best take a trip to the dealers then. Was hoping someone would notice that a rubber grommet was missing! LEESY
Post #291244 Sun Mar 06 2011 11:01am
Supacat
Just to confirm that these do pivot & that is normal - as they are designed to do.
Post #291277 Sun Mar 06 2011 7:16pm
LEESY
Cheers for letting me know LEESY
Post #291286 Sun Mar 06 2011 8:14pm
