![]() | Home > Technical > Please help identify this part - (pic) |
ciaa Member Since: 31 Mar 2009 Location: Dubai Posts: 70 ![]() ![]() ![]() |
These are the 'Harmonic Mass Dampers'
LEESY Member Since: 25 Mar 2010 Location: Manchester Posts: 14 ![]() ![]() ![]() |
both of them pivot and swing like elvis!
BulletProofBomb Member Since: 12 Jan 2010 Location: Lanarkshire Posts: 164 ![]() ![]() ![]() |
Uh huh.
Sorry, I've no idea but I couldnt resist.
td6006 Member Since: 20 Feb 2010 Location: wales Posts: 45 ![]() ![]() |
HI MINE IS FITTED WITH THE SAME DAMPENNERS AND I HAD A KNOCKING NOISE FROM THE BACK SAME AS YOU AND TO BE HONEST I THOUGHT IT WAS COMING FROM THESE, BUT AFTER TAKING TO A MATE WHO IS A TOP MECHANIC, ONE LOOK AND TOLD ME IT WAS REAR ANTI ROLL BAR BUSHES.TOOK TO MAIN DEALERS HAD CHANGED PROBLEM SOLVED. I THINK IT COST ABOUT �109 SO NOT THAT BAD. HOPE IT HELPS REGARDS TD6 |
Best take a trip to the dealers then. Was hoping someone would notice that a rubber grommet was missing! LEESY |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Just to confirm that these do pivot & that is normal - as they are designed to do. |
Cheers for letting me know LEESY |
