Home > Technical > Vibration from steering wheel problem RRS
bmwbmwbmw
United Kingdom 2009 Range Rover Sport TDV6 HSE Java Black
I have a RRS 2009 model (before facelift), which i bought brand new in April 2009. After a few months the vehicle developed a vibration issue which seemed to shot up the steering wheel from the front of the car, it got to the point that is was so uncomfortable to drive and therefore i contacted the main dealer.
They said to me that it was a problem with RRS model and the fix was to attach some weights to i believe the axle to sort the problem.
I got the car back and low and behold the vibrations have returned am really at a loss as to what the problem is and with my warranty running out in 13 months i want to get it fixed.
I must also say the problem only really happens when am driving on a straight line and if I go over the smallest of bumps i feel the vibration, it happens at all speeds.
Does anyone know if there is a new fix?
Post #288448 Tue Feb 08 2011 7:12pm
If you change your user name you might get some help Rolling with laughter Thumbs Up
Post #289258 Wed Feb 16 2011 9:32am
Mitch6176
Scotland 2009 Range Rover Sport TDV6 HSE Santorini Black
I put my 09 RRS into the dealer last week as was also suffering a vibration/shudder in the steering wheel that I likened to the front wheels being out of alignment when I was trying to describe it. I was the same - it was all speeds and road surfaces that I felt in on.
They had a look and ended up doing some work on the front bushes. I'm not sure of the technical in's and out's of what they did, and I don't think they replaced them, but whatever they did has worked though as I'm no longer getting the vibration.
Might be worth asking your dealer to have a look in the same area.
Post #289274 Wed Feb 16 2011 11:12am
C10KO
I was experiencing the same problem but only when accelerating and braking. The problem then got worse and I felt vibrations even when driving.
The dealer changed the wheels from 20" to 19" claiming that the problem was in the rims Confused
The problem however was solved Thumbs Up
Post #289302 Wed Feb 16 2011 2:37pm
Mitch6176
Strangely enough, when mine was in the dealer last week, at the same time they did whatever they did with the bushes they put my new 20" wheels on and took 19"s off.
It'd been with my 19"s on that the vibration was noticed, and those rims were pristine.
Confused indeed!!
Post #289308 Wed Feb 16 2011 3:06pm
There was talk of rims "warping" on the inner edge, causing vibrations.
Take the car to an independent tyre specialist and get them checked on their spinning balancer thingie.. RRS gone
Post #289311 Wed Feb 16 2011 3:22pm
C10KO
for me it was clearly the rims - strangely enough as they were overfinch Confused
Post #289324 Wed Feb 16 2011 5:51pm
