![]() | Home > Technical > Vibration from steering wheel problem RRS |
If you change your user name you might get some help |
Mitch6176 Member Since: 31 Jan 2011 Location: Edinburgh Posts: 47 ![]() ![]() ![]() |
I put my 09 RRS into the dealer last week as was also suffering a vibration/shudder in the steering wheel that I likened to the front wheels being out of alignment when I was trying to describe it. I was the same - it was all speeds and road surfaces that I felt in on.
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
I was experiencing the same problem but only when accelerating and braking. The problem then got worse and I felt vibrations even when driving.
Strangely enough, when mine was in the dealer last week, at the same time they did whatever they did with the bushes they put my new 20" wheels on and took 19"s off.
There was talk of rims "warping" on the inner edge, causing vibrations.
for me it was clearly the rims - strangely enough as they were overfinch ![]() |
