Home > Technical > HELP - Front pass door does not lock!
Afini
2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hello guys, having a problem with the front passenger side door on 2006 RRS. The door now fails to lock. At first it would not unlock but now i've manually unlocked it through the key, it won't lock again. I can't lock it from the remote or manually as the key hole seems jammed and i fear breaking my key in there if i try too much. When the unlock button is pressed on the remote or the internal unlock button, the latch remains in its lock position but the door is still unlocked.
Can somebody help me, or will i have have to go to the stealers and get shafted! Confused
Post #288422 Tue Feb 08 2011 2:46pm
scarey
sounds like it might be frozen, leave it in the sun for a while and see what happens..
Post #288423 Tue Feb 08 2011 3:08pm
rajhirani
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Hi,
it sounds like the door latch part has gone faulty.
they are about £40 from the dealers, they will charge about 1.5 hours to fit them.
hope this helps RRS MY2012 AutoBiography
Post #288424 Tue Feb 08 2011 3:14pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
the missus noticed that drivers door wasnt locking today.
watching from inside the lock closes a bit but it appears as though the locking solonoid is lacking power to close fully. interior locking switch closes it a bit more but not enough.
it is a bit cold today so maybe a dodgy cable.
reading the posts on the Disco3 website im not suprised really.
anyone had the same or similar?
Post #289117 Mon Feb 14 2011 8:47pm
I had the same problem with my drivers door, dealer quoted me £136 to be fixed, it was the door lock that had actually broke, quite common, fortunatly i had mine fixed under warranty.
Ady
Post #289128 Mon Feb 14 2011 9:30pm
MGO
drivers side lock is working perfect today!
mmm Question Neutral
Post #289224 Tue Feb 15 2011 7:36pm
