Home > Technical > Sat nav help!
T77OMY
2006 Range Rover Sport TDV6 S Zermatt Silver
Sat nav help!
Hello I recently purchased a sport 2006 2.7 S it doesn't have sat nav, how can I get sat nav in? Software update? Total new unit?
Thanks
Post #287568 Mon Jan 31 2011 9:18pm
BKHK
Buy a Tom Tom or aftermarket system and stick it in the slot. To retrofit an OEM style Nav System would be very expensive and not easy. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #287580 Mon Jan 31 2011 11:05pm
stickinthemud
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Fuji White
If you get a tomtom you can use the 'home mount' with the fitted USB lead. This is normally meant to hook up to your PC. Pull off your centre radio console surround, the bit you left knee can touch to the side, it just clicks out and the feed the wiring behind and out to the 12v socket. It looks neat and is easy to remove or cover. The TT XXL is the biggest screen but doesn't have all the phone bluetooth and live traffic. I did this on my Disco 3 S and it was fine.
Post #289188 Tue Feb 15 2011 2:31pm
