Home > Technical > "Suspension Fault" Message - Please Help!
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
kevinlagan wrote:
Latest update - car back from the garage and is now 100%. Two pipes leading to air suspension at front wheels replaced. Diagnostic fee of £40 + labour...£290. Could have been worse I guess.
u got off lightly there mate Thumbs Up
Post #288006 Fri Feb 04 2011 9:45pm
kevinlagan
Northern Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Definitely did! Sometimes posting for help on here scares the life out of you but gave me a fair idea of what it might be.
Post #288037 Sat Feb 05 2011 8:44am
kevinlagan
Spoke too soon. Same light back on again at the weekend! Completely fed up now. Thought it was sorted. Back to the garage she goes!!!
Post #288354 Mon Feb 07 2011 11:25pm
barry15555
England 2006 Range Rover Sport Supercharged Bonatti Grey
Had the same problem over the weekend, Removed the cover on the compressor, squirted the compressor with washing up liquid (missing the electricals) found there was a air leak on a plastic piece connected to the pump uncliped it found a o ring replaced it now fine. Hope this helps Thumbs Up' 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels.
Post #288357 Tue Feb 08 2011 12:18am
soody
2008 Range Rover Sport TDV8 HSE Java Black
I have exactly the same problem with my 08 tdv8. Its in to the dealers tommorow.
Post #288376 Tue Feb 08 2011 10:53am
kevinlagan
The difference between the light coming on now is that there are no air leaks when car is parked and turned off and does not lower excessively on one corner. However when I am driving and the light comes on, the acess/raise height fuction does not work! When i go back to drive it the next day, the access height button works fine. Mystified.
Post #288543 Wed Feb 09 2011 2:53pm
kevinlagan
Sorry to keep resurrecting the thread but does anyone know if the suspension fault could be causing a battery drain as this is the latest issue to manifest itself. Took the intermittent fault light issue back to mechanic (which seems to be accompanied by whirring noise from the compressor on start-up). He doesn't want to know! As far as he is concerned, he can't (or won't do any more). Joke! Seems like £300 wasted IMO. Do I have any comeback on this? Any advice much appreciated.
Post #290858 Wed Mar 02 2011 4:10pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
hi is there a way of testing for a faulty height sensor as i get the light on but when i switch it of and back on it goes then few minutes later its back with the message and i cant higher or lower the vehicle until i switch the engine back of then on again have checked to see if the suspension is lowering over night but it doesnt so was thinking it might be a sensor any ideas thanks Sad
Post #291567 Tue Mar 08 2011 11:26pm
tedi
Ireland 2007 Range Rover Sport TDV6 S Stornoway Grey
I had the exact same issue, but it turned out to be a pin-hole air leak in the tank. I only found it because I could hear a faint hiss when I parked up - thinking I had another bloody puncture!!
Just sanded it down and filled it with a bit of chemical metal. Hasn't happened since.
Post #293417 Thu Mar 24 2011 12:10am
dazzerboy
left vehicle for a week lowered itself started engine today front lifted then back lifted to normal height is this normal or do i have a leak in the compressor somewhere Rolling Eyes
Post #293456 Thu Mar 24 2011 11:46am
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
I had 3 compressors on mine (used from ebay....). Symptoms were "Suspension Fault" and "Vehicle is Raising Slowly". Seemingly there is a common problem with the exhaust port valve on the Air Suspension Compressor which caused it to over-work and get too hot.
Replacing the compressor is not a difficult job, I can do it in 35 minutes.
Hope this helps.
Post #294839 Sun Apr 03 2011 1:16am
