Home > Technical > "Suspension Fault" Message - Please Help! |
kevinlagan Member Since: 06 Mar 2010 Location: Bangor Posts: 44 |
Definitely did! Sometimes posting for help on here scares the life out of you but gave me a fair idea of what it might be. |
Sat Feb 05 2011 7:44am |
Spoke too soon. Same light back on again at the weekend! Completely fed up now. Thought it was sorted. Back to the garage she goes!!! |
Mon Feb 07 2011 10:25pm |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 |
Had the same problem over the weekend, Removed the cover on the compressor, squirted the compressor with washing up liquid (missing the electricals) found there was a air leak on a plastic piece connected to the pump uncliped it found a o ring replaced it now fine. Hope this helps ' 2006 S/C Bonatti Grey, OEM Steps, LAND ROVFR Mud Flaps, Soft/Smooth steering wheel, 2010/11 HST Wheels. |
Mon Feb 07 2011 11:18pm |
soody Member Since: 14 Jan 2009 Location: Tyne and Wear Posts: 33 |
I have exactly the same problem with my 08 tdv8. Its in to the dealers tommorow. |
Tue Feb 08 2011 9:53am |
The difference between the light coming on now is that there are no air leaks when car is parked and turned off and does not lower excessively on one corner. However when I am driving and the light comes on, the acess/raise height fuction does not work! When i go back to drive it the next day, the access height button works fine. Mystified. |
Wed Feb 09 2011 1:53pm |
Sorry to keep resurrecting the thread but does anyone know if the suspension fault could be causing a battery drain as this is the latest issue to manifest itself. Took the intermittent fault light issue back to mechanic (which seems to be accompanied by whirring noise from the compressor on start-up). He doesn't want to know! As far as he is concerned, he can't (or won't do any more). Joke! Seems like £300 wasted IMO. Do I have any comeback on this? Any advice much appreciated. |
Wed Mar 02 2011 3:10pm |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
hi is there a way of testing for a faulty height sensor as i get the light on but when i switch it of and back on it goes then few minutes later its back with the message and i cant higher or lower the vehicle until i switch the engine back of then on again have checked to see if the suspension is lowering over night but it doesnt so was thinking it might be a sensor any ideas thanks |
Tue Mar 08 2011 10:26pm |
tedi Member Since: 17 Jan 2007 Location: N.W. Ireland Posts: 21 |
I had the exact same issue, but it turned out to be a pin-hole air leak in the tank. I only found it because I could hear a faint hiss when I parked up - thinking I had another bloody puncture!!
Wed Mar 23 2011 11:10pm |
left vehicle for a week lowered itself started engine today front lifted then back lifted to normal height is this normal or do i have a leak in the compressor somewhere |
Thu Mar 24 2011 10:46am |
acowx Member Since: 21 Jun 2009 Location: New Freedom Posts: 61 |
I had 3 compressors on mine (used from ebay....). Symptoms were "Suspension Fault" and "Vehicle is Raising Slowly". Seemingly there is a common problem with the exhaust port valve on the Air Suspension Compressor which caused it to over-work and get too hot. Replacing the compressor is not a difficult job, I can do it in 35 minutes. Hope this helps. |
Sun Apr 03 2011 12:16am |
