Home > Technical > battry light on ??
johnsmall
battry light on ??
hi guys
just joined the forum.. sorry to bother you with a problem straight away but i have just (2 weeks ago) bought a rr sport hse 2.7 d auto.
so far so good loving it. but driving it 2 days ago battery light came on i was a little concerned but 5 mins later went off. started car yesterday battery light was on i thought it would go out after a while but no it stayed on for the entire journey (50 miles) driving it in dark with lights etc on
just done a check on the battery after vehicle been parked up overnight thought it would be a low reading battery reading about 13 volts without engine running... started engine tested the battery again same 13 volts
car sounded ok on turning over didnt sound slow.
i thought if the batt was the problem it would not have read 13v but if it was the altinator same thing realy would not have put any charge in the batt ??
any help much appreciated.
ps
exellent forum look forward to speaking to many of you now im a rr owner
john
Post #284202 Tue Dec 28 2010 12:36pm
Rislar
Alternator bud, mine did the same, then it ended ruining the battery also!! If it aint broke leave it!
MY 18, Autobiography
MY 05, 07, 10,
Post #284203 Tue Dec 28 2010 12:42pm
johnsmall
thanks ... thought it was but like to get other opinions looks like i need to get this changed soon anyone know the cost of altinator 2.7 d fitted.
anyone bristol area know of a good rr repairer.. not under warrenty
john
Post #284204 Tue Dec 28 2010 12:46pm
Linko
I had this done on my TDV8 recently. Same sort of symptoms as you except the battery died too.
Cost of:
    Gen LR Service Exchange Alternator: £161.44 + VAT
    Coolant replacement LR supplied: £32.15 + VAT
    Labour on a TDV6 should be 1.5 hours at whatever rate your repairer charges.
On the TDV8 it takes 3.8 hours! Big Cry I was at the LR dealer (as that's where i got recovered to when it died), their rate was £115 per hour (+ VAT). However the Service Manager did me a bit of a discount and knocked the .8 hour off as it was the season of goodwill! Shocked
Hopefully someone on here will be able to recommend a good local indy for you that charges a decent rate! Thumbs Up
Good luck!
Mark
Post #284253 Wed Dec 29 2010 10:56am
johnsmall
Thanks for the replies. Strange difference v8 times and costs trying to book in as Im typing to steve hill bristol seems to have a good reputation. A few on here use him and says he's good so that's good enough for me. Thanks again for the replies
John
Post #284257 Wed Dec 29 2010 11:33am
ricknchi
tdv6 alternator replacement is a lot easier than a tdv8 alternator replacement and should be a lot less in labour
Post #284545 Sun Jan 02 2011 6:36pm
johnsmall
hi
new alternator fitted cost was £391.03...fitted at steve hill in bristol good service. phoned main dealer for cost and availability of alterator cost was £185 just for part but they could not get one for two days, so i took it to steve hill had new alternator fitted same day JOHN
2005 RR SPORT BLACK COLOUR CODED 22" WHEELS CREAM LEATHER
Post #285565 Tue Jan 11 2011 1:14pm
